[Homework Help] Solving Seperable Differential Equations
14 replies · 3K views
IareBaboon
Hi, this is my first time posting a homework help problem, so please excuse any mistakes I happen to make :) I actually have two problems I'm stuck on. I have been trying to figure it out, and I'm sure it's a very simple problem, but I guess I'm just not that bright. Anyways, here they are.
1) Find the particular solution of the differential equation for:
[tex]11x-6y\sqrt{x^2+1}\frac{dy}{dx}=0[/tex]
2) Find all values of k for which the function [tex]y=sin(kt)[/tex] satisfies the differential equation [tex]y''+16y=0[/tex]
For the first question, you're told to use the following initial condition: [tex]y(0)=4[/tex]
So for the first question, what I did was bring the x's to the right side and then got stuck at the integral part, which is this:
[tex]\int-6ydy=\int\frac{-11x}{\sqrt{x^2+1}}dx[/tex]
The left hand side is easy to integrate, however how would I go about integrating the right hand side? That's where I'm getting stuck at. A quick rundown would be very appreciated.
As for the second question, what I think I'm supposed to do is take the derivative of [tex]y=sin(kt)[/tex] twice, so that I have the second derivative of y, then substitute it into the original equation. Would that be right?
Thank you very much for any help. Anything would be appreciated :)
I'd use a u-substitution to integrate the right side.
as for the second one, if I am understanding you right, that is the right approach
Alright. Thanks guys :) I think I can do the first question now. But the second question is a tad bit confusing. So let's say I take the first derivative of [tex]y=sin(kt)[/tex] which becomes [tex]y'=kcos(kt)[/tex] right? And then I take the second derivative of that, which is [tex]y''=-k^2sin(kt)[/tex] right?
After finding the second derivative, I plug in [tex]y=sin(kt)[/tex] and [tex]y''=-k^2sin(kt)[/tex] into [tex]y''+16y=0[/tex] which then makes it into [tex]-k^2sin(kt)+16sin(kt)=0[/tex]. What do I do at this point to find all values of k that would satisfy the differential equation [tex]y''+16y=0[/tex]?
Sorry if it's confusing to read. But thanks a lot for the help :)
Factor out the sin(kt) term on the left hand side and it comes down to finding the zeros of both sin(kt) and 16-k^2, which is easy.
Oh wow I can't believe I missed something so obvious. Lol thanks a lot for pointing that out to me. I got the right answer now :)
Really sorry for double posting, but I'm still having troubles with the first question. This is what I've done so far after moving the x's to the right side:
[tex]-3y^2=\int\frac{-11x}{\sqrt{x^2+1}}dx[/tex]
U-substitution for right side
[tex]u=x^2+1[/tex]
[tex]du=2xdx[/tex]
[tex]-5.5du=-11xdx[/tex]
[tex]-3y^2=-5.5\int(u^\frac{-1}{2})du[/tex]
[tex]-3y^2=-5.5\frac{u^\frac{1}{2}}{\frac{1}{2}}[/tex]
[tex]-3y^2=-11(u^\frac{1}{2})[/tex]
[tex]y=\sqrt{\frac{-11(x^2+1)^\frac{1}{2}}{-3}[/tex]
That's what I'm getting. I know it's wrong, because the intitial condition given was [tex]y(0)=4[/tex] and when I plug in 0 into the x's, I'm not getting 4. What am I doing wrong? (Sorry if I'm bothering you guys by now. I just really need to understand this stuff as I have an exam soon...)
all your integration steps are missing the "+C"
use y(0)=4 to solve for "C", and add it to your equation!
Ah, right, forgot about the C. But I don't think that's what the question is asking for. Here's the question (My homework is posted on the web, :))
EDIT: Woops, just saw the last line of your last post just now. Let me do that and I'll get back to you.
Okay, so I got the C which is 2.085145784. So what I get now is [tex]y=\sqrt{\frac{-11(x^2+1)^\frac{1}{2}}{-3}}+2.085145784[/tex] yet when I submit it online, the webworks says I am wrong. I really don't get what I'm doing wrong.
edit:///
i dunno.
lol its fine. thank you for the help though, much appreciated.
The C should be inside the square root because it comes in integration when y is still squared:
[tex] \int-6ydy=\int\frac{-11x}{\sqrt{x^2+1}}dx \Leftrightarrow 3\int d(y^2)= 11\int{d(\sqrt{x^2+1)} \Leftrightarrow y^2 =\frac{11}{3} \sqrt{x^2+1} + C[/tex]
Now solve for C using the initial condition.
Ah, thanks to everyone! I got the answer now :)
An airplane is flying with a velocity of 82.0 at an angle of 24.0 above the horizontal. When the plane is a distance 108 directly above a dog that is standing on level ground, a suitcase drops out of the luggage compartment. Help please!
