Are Maps on a Sphere Homotopic if They Avoid Antipodal Points?
  • Thread starter Thread starter R136a1
    Sphere
R136a1
If I take two arbitrary continuous maps ##f,g:S^n\rightarrow S^n## such that ##f(x) \neq -g(x)## for any ##x\in S^n##, then ##f## and ##g## are homotopic.
How do I show this result? I really don't see how to use the condition that ##f## and ##g## never occupy two antipodal points. Any hint would be appreciated.
Consider the straight line homotopy ##H(x,t) = f(x) + t(g(x) - f(x))##. Try to force the straight line homotopy onto the sphere; you'll see how the constraint on ##f(x)## and ##g(x)## not occupying antipodal points comes into play.
Thanks a lot, miss!
So, my idea is to take
H(x,t) = \frac{f(x) + t(g(x) - f(x))}{\|f(x) + t(g(x) - f(x))\|}
I guess the constraint on ##f## and ##g## comes into play because we don't want the denominator to vanish? But I have troubles proving this rigorously. Assume that the denominator is ##0##, then
(t-1)f(x) = tg(x)
I'm pretty stuck now!
##f(x)## and ##g(x)## are both elements of ##S^{n}##; take the norm of both sides.
Wow, I didn't think of that! Why are you so smart?
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
