How can a particle be a combination of other particles?
Buzz Bloom
Moderator's note: this is a spin off from a previous thread here.
I confess to a very limited understanding of QM. I understand (somewhat) that a state of a particle can be a combination of possible states. I do not understand how a particle can be a combination of two particles. In particular, a particle has measurable properties such as: energy, momentum, position, and time of measurement. Of course there are uncertainty constraints on the precision of such measurements, and predictions about measurements are probabilistic. Can you explain the physics of how the energy, momentum, position, or time of measurement of a single particle can be a combination of such measurements of two particles.
That's not what is being described when a particle is expressed as a "combination of two particles".
The example in the previous thread was the electroweak bosons. At very high energy (such as in the very early universe, before the electroweak phase transition), the electroweak bosons are ##W^1##, ##W^2##, ##W^3##, and ##B##. At low energy (after the electroweak phase transition), they are ##W^+##, ##W^-##, ##Z##, and ##A##, where ##A## is the photon. We can write the second set in terms of the first as follows:
W^+ = \frac{1}{\sqrt{2}} \left( W^1 + i W^2 \right)
W^- = \frac{1}{\sqrt{2}} \left( W^1 - i W^2 \right)
Z = \cos \theta W^3 - \sin \theta B
A = \sin \theta W^3 + \cos \theta B
What do these equations mean? They do not mean that the ##Z## boson, for example, is measured by measuring a ##W^3## and measuring a ##B## and combining the measurements in some way. What these equations mean is this: what we call the ##Z## boson, for example, is really a quantum field state which is a combination of the ##W^3## state and the ##B## state, in a certain ratio. That state happens to be the one we can detect in particle physics experiments; we can't detect ##W^3## or ##B## states at the energies accessible to us. But all of them are just quantum field states, they are not "different particles". They are just different possible states of the field, which can combine in different ways to form new states.
Another way to look at this, which was touched on in the earlier thread, is to think of the two groups of bosons, ##W^1##, ##W^2##, ##W^3##, and ##B##, vs. ##W^+##, ##W^-##, ##Z##, and ##A##, as two different sets of basis vectors in the "space" of electroweak quantum field states. On this view, the equations above just express a transformation in electroweak field space from one basis to another. Any possible electroweak field state can be expressed in either basis, and you get the same predictions for all observables no matter which basis you use. It's just that the second basis is more convenient at the energies we can currently probe experimentally, because those basis states are the ones we can detect.
Likes Buzz Bloom
I don't really disagree with this which basically explains the answer. But, I do feel like there are one or two unstated assumptions lurking in the electroweak unification story that are not articulated which makes this reasoning less obvious than it should be, although I can't quite put my finger on exactly what those assumption are or should be.
Something similar comes up with the lighter pseudo-scalar mesons like the neutral pion (which is a "combination" of u/u bar and d/d bar) and neutral kaon (which is a "combination" of long and short versions) (I recognize that I may not be using precisely the right terminology here, but bear with me). It is all good and well to say that this is how the reality works, but there are unstated assumptions about what that means and about why it can happen in some circumstances and not others that aren't well articulated in the standard simplified quark model explanation of hadrons.
For the neophyte, the practical solution is to simply treat them like irregular verbs in French that you memorize and don't ask why. But, it would be useful to have an intermediate level of explanation between "it's that way because Nature says so" and a full blown understanding of QCD at a level why some hadrons are mixes, and other are not which probably goes along the lines of "all of the quark content models are oversimplifications are what are really combinations of all possibilities that can produce the same quantum numbers for the composite particle, but if its 98%+ one state, it is convenient to treat them as if they are just one state", which would be O.K. is there was some explanation of why we see the mixes that we do. Hell maybe we really don't know (in which case this should be made more clear as an unsolved problem of physics), but I think that we know more than we do a good job of explaining to the interested educated layman.
Likes Buzz Bloom
It's going to be hard to discuss this if you can't be specific. Certainly my previous post was not intended to be a complete or even close to complete discussion of electroweak unification. I was only explaining the particular point that the OP asked about.
I'm not sure what you mean by "the standard simplified quark model of hadrons". Again, it's hard to discuss if you can't be specific. Do you have a particular reference you can give that illustrates what you're talking about?
I'm not sure what this means either. What are "mixes", and how do they differ from things that are not "mixes"? Again, a reference would really be helpful because I'm not understanding the issue.
This is probably true, but I'm not sure "doing a good job" involves quite what you think it does. Many people seem to think that there should always be a way of explaining these things that makes them simple and intuitive, without realizing that often, the reason it seems like experts in the field see them as simple and intuitive is that they have painstakingly retrained their intuitions. A layman's intuitions are simply not well matched to physical phenomena that are outside of normal everyday experience.
Likes Buzz Bloom
You are incorrect about the measurement being probabilistic, nature itself is. It's still one particle, it just exists in every location in it's path at the same time, that's not a fault of the measurement, that's how nature actually seems to be. You say it has a measurable properties, that's true, but position is not one of them. It only has a position upon being measured. It's not that we didn't know it's location because we didn't measure it, it's that it literally doesn't have position until it's measured.
This is not really a good description of what is going on; it implies that the particle has multiple positions at one time, rather than that the particle doesn't have a well-defined position at all until it's measured (which is a better description, and the one you give later in your post).
(Also, even if we admit "having multiple positions at one time" as a candidate for a sloppy heuristic description of what's going on, based on the path integral formalism, it's still not right as you state it. The multiple "positions" that the particle has at one time are not multiple positions along one path; they're single positions on multiple possible paths that the particle could take.)
Likes Buzz Bloom
This is exactly the point. Below electroweak symmetry breaking, the fields with definite masses are the ##Z##, ##A##, and ##W^\pm##, not the ##W^{1,2,3}## and ##B##. Above electroweak symmetry breaking the gauge bosons all become massless and it becomes more meaningful to talk about the fields in terms of their interactions. The ##W^{1,2,3}## are the gauge bosons of the non-Abelian SU(2) gauge group with coupling constant g', while the hypercharge gauge boson ##B## belongs to the Abelian hypercharge U(1) with coupling constant g.
Similar concepts are behind all particle mixing, the mass eigenstates are generally not the states in which the interactions are diagonal. This leads to phenomena as K-Kbar or neutrino oscillations as well as to weak decays of heavy quark generations to lighter.
Orodruin said:
Above electroweak symmetry breaking the gauge bosons all become massive
Do you mean "massless"? If electroweak symmetry is unbroken, the ##W^1##, ##W^2##, ##W^3##, and ##B## bosons are all massless (like all of the Standard Model fields), correct?
Yes, thanks. Updating the post.
Hi @Orodruin:
I had the imprssion that the emerging of the Higgs boson and the resulting particle masses took place when the strong force separated from the electro-weak, not when the EM force separated from the weak? If I am incorrect about this, it seems to me there are two main possible scenarios (with some additional possible minor variations):
1. Step 1: Higgs boson emerges and EM separates from weak. Strong remains unified with weak and also with EM. Step 2. Strong separates from weak or EM in some order. Step 3. Strong separates from the last still unified force.
2. Higgs boson emerges and EM, weak and strong all de-unify concurrently. I confess this possibiity seems most unlikely to me; its too much of a coincidence that all of this distinct separations would happen concurrently.
Which of these is right, or is there another explnation? If (2) is right, can you explian tha apparent coincidences?
Regards,
Buzz
Neither is correct. Unification is assumed to be broken at an even higher scale (which is why you talk about three forces and not one).
The electroweak symmetry breaking breaks the electroweak SU(2)xU(1) symmetry of the Standard Model down to a different U(1), which is the electromagnetic interaction. the SU(3) of strong interactions remains unbroken.
Hi newjerseyrunner:
I apologize for my sloppy phraseology. How about:
A particle has properties about which the distribution of probabilities of possible measured values can be calculated.​
Is this OK?
Regards,
Buzz
Hi @Urodruin:
Sometimes I get a strong impression that my failure to understand physics is not so much due to the difficulty of the concepts, but to the odd dialect of english that physisists use to explain these concepts. Perhaps it's just the physicsese. ;)
Can you explain in simple language what is different in the two statements:
(1) What I quoted above.
(2) What I quote below.
You seem to saying that the breaking of symmetry is not all concurrent, and that electo-weak breaks first. Is that correct?
Regards,
Buzz
PeterDonis said:
what we call the ZZ boson, for example, is really a quantum field state
Hi @Peter:
I think a lot of my confusion relates to a misunderstanding of how (1) QM theory about particles and their states relate to (2) QFT and quantum fields whose states are particles. I have had the confused idea that a quantum field was similar in some physical way to a classical field, e.g., an EM field. Is there a QFT about photons, and if so, is there a theorectical or mathematical connection between such a QFT and the Maxwell equations that define the behavior of the EM fields?
Regards,
Buzz
No. Here's the order of symmetry breaking (with reference to the Standard Model interactions):
First, the grand unification symmetry (which unifies all three of the interactions--strong, weak, and electromagnetic) is broken. After this symmetry breaking, there are two interactions: strong and electroweak. In terms of symmetry groups, this symmetry breaking splits up the complete symmetry group of the Standard Model, which is SU(3) x SU(2) x U(1), into two parts: the SU(3) of the strong interaction, and the SU(2) x U(1) of the electroweak interaction.
Then, the electroweak symmetry (which unifies the weak and electromagnetic interactions) is broken. This involves the Higgs field acquiring a vacuum expectation value, which causes the Standard Model fermions and the weak interaction gauge bosons to acquire mass, and the Higgs boson to emerge. After this symmetry breaking, there are three interactions: strong, weak, and electromagnetic. In terms of symmetry groups, this symmetry breaking splits up the SU(2) x U(1) symmetry of the electroweak interaction into two parts: the SU(2) symmetry of the weak interaction, and the U(1) symmetry of the electromagnetic interaction. (There is a twist here in that this U(1) is a different U(1) from the one that appears in the unbroken SU(2) x U(1) symmetry of the electroweak interaction.) The SU(3) of the strong interaction remains unchanged by electroweak symmetry breaking.
Likes Buzz Bloom
Does this imply that at some energy scales, before electroweak symmetry breaking, that fermions are massless?
Yes.
Likes Buzz Bloom
Orodruin said:
Yes.
Is this region accessible by current methods? It sounds very interesting.
Hi Peter:
Thank you very much for your post. Your post has the most clear statements I have ever seen about the sequence of symmetry breaking events and the role of the Higgs field/particle. I finally feel that I now understand this, althought the Lie group stuff is still over my head.
I think the main reason for all my confusion was accepting the following as correct from https://en.wikipedia.org/wiki/Grand_Unified_Theory :
The novel particles predicted by GUT models are expected to have masses around the GUT scale. . .​
This seems to me to be clearly inconsistent with the quotes above by implying that the Higgs field caused particles to acquire mass before or during the GUT symmetry breaking, rather than later during the electroweak symmetry breaking. I hope you don't mind my suggesting that you would help many future interested users of Wikipedia regarding this topic by your correcting this Wikipedia error.
Regards,
Buzz
Unfortunately, no, not by many orders of magnitude.
What this means is that, if we tried to detect such particles in our current universe, those are the masses we would have to be able to detect--which means we would have to be able to run experiments that involved particles with energies of that order of magnitude. We are many orders of magnitude short of being able to do that.
As I understand it, in grand unified theories, the Higgs field that is involved in electroweak symmetry breaking is not the "entire" Higgs field; it's only a piece of it. There is another piece of the Higgs field that is involved in grand unified symmetry breaking, and gives mass to the GUT bosons after that symmetry breaking event, and leaves behind what we usually call the Higgs field, the one that's involved in electroweak symmetry breaking.
However, we haven't observed any of the GUT bosons, and, for the reason I gave above, we don't expect to any time soon. So we don't really have any experimental test of the GUT Higgs mechanism, whereas we do have experimental tests of the electroweak Higgs mechanism. So we don't really know for sure how the GUT bosons acquire mass, the way we know how the weak bosons acquire mass. We don't even know for sure which GUT, if any, is the right one; there are multiple possible GUT's that are consistent with what we currently know.
Likes Buzz Bloom
Hi Peter:
Thank you for clarifying what the Wikipedia article's language meant, and that the Wikipedia text (technically) was not in error. It just used the Physicsese dialect in a different way than other uses, e.g., your excellent and clear exposition in your post #15.
I get that there seems to be a very extensive reluctance to "fix" Wikipedia text when is is not tecnically wrong, just only misleading and confiusing to non-experts. My own feeling about this is that it's a sad shame.
Regards,
Buzz
I think the reluctance is due to the fact that one does not have to be an expert in the subject to edit a Wikipedia article, so even if an expert makes a change, a non-expert can come along and undo it, or make another change that negates it. So there's a limit to how much time and effort experts are willing to put in.
Hi @PeterDonis:
Thanks for your insight into the psychology about "fixing" Wikiedia. I understand from multiple personal expeiences the frustration of trying to correct Wikipedia text when there is someone with more patience and stamina for unfixing than I have for fixing.
Here is the entire Wikipedia paragraph with the misleading and confusing text.
The novel particles predicted by GUT models are expected to have masses around the GUT scale—just a few orders of magnitude below the Planck scale—and so will be well beyond the reach of any foreseen particle collider experiments. Therefore, the particles predicted by GUT models will be unable to be observed directly and instead the effects of grand unification might be detected through indirect observations such as proton decay, electric dipole moments of elementary particles, or the properties of neutrinos. Some grand unified theories predict the existence of magnetic monopoles.​
I underlined "masses", the single word that I believe causes "the problem". Do you think changing "masses" to "energies" would fix "the problem"? Do you think making this change would be controversial?
Regards,
Buzz
About a month ago I changed "masses" to"energies " in the Wikipedia article
The change is still there, so maybe it is worthwhile sometimes to make the effort to make a change and then hope for the best.
Your change is misleading and should be reverted. That nobody has done so yet just shows that people with sufficient knowledge are not paying attention.
I do not get why you keep wanting to change Wikipedia on subjects you do not fully understand. I would call this vandalism.
Likes vanhees71
Hi Orodruin:
Thanks for your post. From your comment that my edit is "misleading", I get that you looked at the edit and formed this conclusion. I would very much appreciate understanding your reason for this conclusion.
The reason I try to improve Wikipedia, even though I am not an expert, is because Wikipedia says they want people like myself to help improve the quality of their physics articles. Please see:
I frequently find text which as a non-expert I find confusing. I would be very happy if experts did the improving by making the text clearer for non-experts to understand, but if they don't, I feel invited to do the best I can.
Regards,
Buzz
I suspect it's because "mass" in particle physics means "rest mass", which is not the same as "energy". The Wikipedia article before you edited it was correct: it said the rest masses of the novel particles predicted by GUT models were around the GUT scale. After your edit, the article is wrong: the energies of such particles can be anything higher than their rest masses, depending on the situation, and those energies are not what is predicted by the GUT models--they can't be, because, as I said, the energy of any given particle depends on the situation, so no physical model will predict a single energy for a particle.
This kind of attitude is a big reason why many experts don't want to spend time and effort to edit Wikipedia articles. What seems clearer to you, a non-expert, is very likely to be wrong, but as a non-expert, you won't know it. So what you think are helpful changes are really destroying the work of experts. As you did with the article discussed above.
The fact that no expert has undone your change doesn't mean it was a good change. It just means that experts don't see the point of trying to correct it, since some other non-expert could come along tomorrow and destroy their work. Again.
Likes Orodruin
You really should not edit unless you are certain. What do you think is worse, that someone finds an article confusing or that someone reads it, think they understand it, and got the completely wrong expression? Many people tend to (unfortunately) take Wikipedia as their standard reference. A physics student doing that will spend time and effort learning things which are not true. Then they come to the exam and fail and the argument "Wikipedia said" does not work as an excuse on most university teachers.
Likes vanhees71 and PeterDonis
Said and done. Please stop vandalising the work of actual experts. This is the second time I have had to revert one of your "improvements". As I remember, also the last time you were unwilling to revert your change even after being told repeatedly that it was not correct.
Likes Doc Al
  • #31
Hi Orodruin and Peter:
Congratulations. I confess you are succeeding in discouraging me from efforts to make Wikipedia physics articles less confusing and misleading to non-experts.
I understand Orodruin's dislike for my mistakes when I try to make improvements. What I don't understand is why with less effort than that required to undo my poor efforts, he doesn't instead just do it right in the first place, or help me understand what the right fix should be. Do either of you disagree that the current language written by experts is misleading or confusing to a non-expert? Do either of you accept that this is so, but feel that it is unnecessary to make it better?
From time to time I discover texts that I misunderstand. I believe the reasons I misunderstand them is that the text includes specialized expert usages of language that are confusing and misleading to non-experts. What I try to do is get clarification from discussions on the forums. I feel that there is, or should be, an opportunity on these forums to get experts to suggest language to fix confusing or misleading Wikipedia text. Why is that a bad idea?
In the last few posts it has become clear to me that "masses" is still confusing and misleading to non-experts in particle physics. While "energies" made it worse, why wouldn't adding "rest" make it better?
The previous post on this thread before today's was dated September 26th. That post includes the following question:
If someone since September 26th had posted that "rest" would fix the text, and that "energies" would make it worse, then I would certainly have used "rest" in my change. Would that have been such a terrible thing to do?
Regards,
Buzz
  • #32
No. I do not agree that it is misleading or confusing. What was wrong here was your interpretation of Peter's posts.
Because it was right already, until you changed it.
Peter tried, that resulted in you misunderstanding his post and doing the wrong edit.
Because as a non-expert, you are likely to miss crucial information and certain details. In order to make relevant contributions, just hanging around and asking people who know is not going to make you qualified to write about it. Unfortunately, this is also true of many journalists who try to write about science.
No, it would make other things worse. In particular, it would counteract efforts of getting the idea of "relativistic mass" out of the mind of the general public. In high-energy physics, we only talk about "mass", never-never-never-never "relativistic mass".
Likes Buzz Bloom
  • #33
Hi Orodruin:
Thanks for your post answering my questions.
I accept as true all of your comments. I confess I find them discouraging. The conclusion I reach is that the language dialects of physicsese for various branches of physics are so precise that any attempts to "improve" text would be counter to the intended nuances of meaning. Therefore it is impossible for a non-professional in a particular branch to avoid being confused and misled by reading specialized text. It seems to me that physics is thus enduring a tower of Babel condition.
Regards,
Buzz
  • #34
I would argue against this as well. Given the inclination, you can go to a university where you can study the language of physics and other natural sciences. As with any language, it takes time and effort to master.
Likes Mentz114
  • #35
Buzz Bloom said:
Hi Orodruin:
Regards,
Buzz
It's a physics article. That is the correct language to write it in. In Wikipedia, the straight article is not intended for didactical purposes (there was a simplified edition of Wikipedia for that, iirc).
Also, even for didactical purposes, "mass" would still be a better term: you misunderstood PeterDonis' post when he said you need higher energies to access the phenomena concerning particles having such masses, and you somehow conflated the two concepts. Thus, rather than Babel's tower condition, there's a Chinese whispers condition to which you are contributing ;)
  • #36
You're missing the point. Somebody already did it right in the first place. Then you changed it to something wrong. If Orodruin, or anybody else, changes it back, what guarantee is there that some other non-expert won't come along tomorrow and change it to something wrong again? Answer: none.
In other words, if you're an expert, trying to keep a Wikipedia article's text correct ends up being an endless game of whack-a-mole. Experts have better things to do with their time. Yes, that means Wikipedia is often not a good source. That, quite frankly, is Wikipedia's problem.
  • #37
Just to elaborate on this: I did not correct it because I want Wikipedia to be correct - as Peter says, that is a Herculean task and there is no guarantee it will not be changed to something wrong tomorrow. I reverted the change because these things could have a detrimental effect on the reputation of Physics Forums. Imagine someone sees your edit and realizes it is wrong - they go to the talk page, get your user name, search for it, and this thread will pop up. All of a sudden, Physics Forums is the place where you got your ideas from and vandalised the Wikipedia article.
  • #38
Hi ddd:
Thanks for your post:
This is what I understood from Peter's and Orodruin' post.
(1) In particle physicsese, "mass" means "rest mass" as opposed to M = E/c2 mass.
(2) GUT models predict the rest mass of particles.
(3) The particular predicted rest mass for a GUT predicted particle requires an extremely high amount of energy to produce such a a particle, either experimentally or naturally. This level of energy is called the GUT scale. This is the scale of energy that was naturally present during the stage of the universe before the strong force separated from the week-EM force.
What did I misunderstand?
Regards,
Buzz
  • #39
You probably should ask that yourself since you ended up editing the article with "energy" which can't be correct, since energy can vary a lot from the rest mass portion (e.g. ultrarelativistic regimes). Your "rest mass" objection is a different one from the first, which you came up with after you figured out you were wrong in the first place: that's a first misunderstanding. The second misunderstanding, different from the first, is the fact that the concept of rest mass really is useless on both fronts:
1) technically, it's just redundant: mass is already rest mass, because relativistic mass is just a flawed concept of old.
2) didactically, relativistic mass only confuses people more (as you are an example), since parallel or perpendicular forces have different results from such a mass: so it's not really what you think about concerning "mass" anyway - your "Babel" problem, in a reductio ad absurdum scenario, is still present and exacerbated if you just start editing all particle physics articles writing "rest mass" instead of "mass".
  • #40
Hi Orodruin:
Thank you for your post. I get and accept your point.
There is one more Wikipedia physics article I have edited. (There are many others for which I have only edited the Talk page.) It is
I tell you this so if you want to you can take a look at it and let me know if you think I should undo it, and why.
Regards,
Buzz
  • #41
Hi ddd:
I misunderstood you post. I thought you were referring to Peter's latest post, when you were instead referring to Peter's post from September when he wrote
You are correct. I did not understand then that Peter's "mass" meant "rest mass" and excluded the alternative meaning of relativistic mass M=E/c2.
Regards,
Buzz
  • #42
Hi ddd:
I do not understand what this quote means. In what way is this a flawed concept?
Regards,
Buzz
  • #44
Basically, writing "rest mass" is misleading since it seems to imply there are other kinds of masses (namely the relativistic mass, which as the article says is a contrived formalism which doesn't correspond to a mass in any concrete sense anyway). Besides, since the whole particle physics field uses the word "mass" a real lot, changing all instances would be insane.
  • #45
Orodruin said:
What is relativistic mass and why it is not used much?
Hi Orodruin:
Thanks for your post and the link. I now get why "rest mass" has become a unwanted usage. So the preferred vocabulary has become:
"mass" always means the inherent mass a particle has (ignoring its kinetic energy). "rest mass" is then redundant, and also by implication suggests an alternative, "relativistic energy" which is concept that has become out of favor.
"energy" means the "total" energy of a particle (including both it's mass equivalent energy and kinetic energy, and maybe also in some contexts its internal exited state energy as well), or with an adjective, a specific kind of energy.
When I was learning this stuff as an undergraduate, a very long time ago, usage was much different. Times change.
Regards,
Buzz
  • #46
Unfortunately, I believe this is still mentioned in some undergraduate modern physics courses, simply because the professors who are teaching them are not specialists in relativity and it is how didactic was when they were learning relativity. If you go to any higher level course or graduate course in relativity, you will most likely not encounter relativistic mass (apart from the professor briefly mentioning that you should not use it).
