How Can D'Alembert's Principle Help Solve This Problem?
  • Thread starter Thread starter Owen Griffiths
    Principle
The discussion revolves around a physics problem involving a 50 kg object being pulled across a rough horizontal surface with a force of 250 N. The problem requires the application of D'Alembert's principle to calculate acceleration, while also considering the effects of friction with a coefficient of 0.4. The original poster expresses confusion over obtaining a negative result when applying D'Alembert's principle, despite having calculated acceleration using conservation of energy.
  • Mixed
  • Participants discuss the relationship between D'Alembert's principle and Newton's laws, with some suggesting that the original poster may have inadvertently applied D'Alembert's principle in their previous calculations. Questions arise regarding the interpretation of inertial forces and the proper setup of the equations.
There is an ongoing exploration of different interpretations of the problem, particularly concerning the application of D'Alembert's principle and the concept of inertial forces. Some participants offer insights into the conceptual challenges faced by the original poster, while others share their own calculations and reasoning without reaching a consensus.
The original poster indicates a lack of familiarity with the subject matter, as they are transitioning into a new career that requires understanding mechanical principles. This context may influence their approach and comprehension of the problem.
Owen Griffiths
Just asking for a little help on this question
50kg object is pulled across a rough horizontal surface with a uniform force of 250N for 15m from rest, the surface has a frictional coefficient of 0.4, calculate the acceleration using dealemberts principle
But this results in a minus answer, so I'm lost, any help would be appreciated!
Conservation of energy, d'alemberts principle
[/B]
I have worked out the acceleration using conservation of energy using
PE+KE+Win = PE+KE+Wout+losses
To find the final velocity, and used
a=v^2-u^2/2s
To find acceleration which comes to 1.08m/s^2
Now the other part of the question is use d'alemberts principle to solve the same problem but I cannot for the life of me work this out, it's probably really simple but I just can't see it
I thought I would go down the route of force in minus the forces against = 0 to find the inertia force and use that to find acceleration, with F = -ma
I think you have already used the de Alembert's Principle in a way, after all how do you evaluate losses, Perhaps You think you have used Energy conservation Principle. But the principle that you have used, Newton's Laws of motion and de Alembert's principle are equivalent to each other and derivable from each other. Just think over. Solving a problem mechanically gives you pleasure may be but not insight. try to develop insight.
Also so called inertial force is not a force at all. That is also creating a conceptual problem, it is the name given to the product ma and because you think it is inertial you give it a minus sign but then you keep it on left hand side only try to equate the sum to zero. Sum of all forces including the so called inertial force = 0 is the principle. Personally I do not like the idea of inertial force at all. It creates more conceptual problems than solve them.
Completely agree on insight, but I'm struggling atm, just a bit of back ground, I'm not a maths or physics student, I'm doing a career change atm and have to study mechanical principle at this level, we have to go through so many topics that I have to admit I very rarely understand the topics we do but rather answer most of the questions parrot fashion, which so far has been surprisingly successful!
But more into the working out
Car Mass: 50kg
Co-efficient of friction is 0.4
N = (mg) = 50 x 9.81 = 490
Frictional Resistance (Fr) = μN = 0.4x490 = 196N
Distance = 15 meters.
PE + KE + Win = PE + KE + Wout + Losses
0 + 0 + (F x Distance) = 0 + (1/2 mv^2)+ 0 + (Fr x distance)
(F x Distance) - (Fr x distance) = 1/2 x mv^2
(250N x 15 meters) – (196 x 15 meters) = 1/2 x 50v^2
(250 x 15 meters) – (196 x 15 meters) / (1/2 x 50) = v^2
32.4 = v^2
5.69 = V
Velocity is 5.69 m/s
Then using
a=v^2-u^2/2s
I come to 1.08m/s^2
Would it be simply
Force - frictional force
250-196= 54
F=ma
54 = 50a
a = 54/50
This equals 1.08 m/s^2 in my first answer
However I thought I must use. F = -ma??
That is the expression for inertial force. Newton's law do not hold good for accelerated frames. So it does not hold good in the frame of the particle where it is at rest. But if we introduce the concept of pseudo force which defined as -ma, where a is the acceleration of the particle in inertial frame, then the law can be made hold true. So in its own frame acceleration = 0 so net force including inertial force = 0 so
Fnet = Fnet in inertial frame - ma = 0 which is nothing but the expression of Newton's law F net = ma in inertial frame. But note that ma is not the result of any interaction. But all those forces thatyou talked about in this problem relate to some interaction except -ma!
9K
  • · Replies 17 ·
  • · Replies 17 ·
