How Can Energy Be Turned Into Matter?
  • Thread starter Thread starter Valo130
    E=mc2
Energy can be converted into mass, and mass can be converted into energy, as expressed in the equation E=mc². This relationship indicates that mass is a form of energy, similar to heat or light. One method of converting energy into matter is through nuclear fusion, where lighter atoms collide at high energies to form heavier elements. Additionally, high-energy photons can create electron-positron pairs upon collision. Understanding these processes highlights the complex interplay between energy and matter in physics.
Valo130
I think i have understood this equation ( don`t be to hard on me, only 15 and have just started to read physics ).
As i understand it says the following :
Energy can be turned into mass, and mass can be turned into energy.
It also says how much energy you get if you turn mass into energy.
Is this right?
Is this right?
Essentially yes, but it might be better to think of it as saying that mass *is* energy - that is, mass is one manifestation of energy, just like heat or light, and can in principle be turned into other types of energy.
This is clearer if we define c=1 (yes, we can do that!), leaving simply E = m.
I understand how you can do matter into energi, when it meets anti-matter and... explodes.
But how do you do energy into matter?
One example is nuclear fusion when creating elements heavier than iron. I'm not sure of the precise process (no doubt it is very complicated) but basically two lighter atom smash into each other at immense energies and fuse together, putting some of the energy into mass. This process only occurs in supernova.
A photon above a certain energy threshold can create an electron-positron pair when it collides with something.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
