How can I collect power from a magnetic field?
To harness power from a magnetic field, it's essential to understand that static magnetic fields do not produce energy. An electric generator converts mechanical energy into electrical energy using magnetic fields, but this process requires an external energy source. The discussion emphasizes that while one can move magnetic materials to generate power, this is not a sustainable method as it depletes the available resources. Additionally, drawing parallels to gravitational fields illustrates that energy extraction typically relies on an external source, such as solar or wind energy, rather than the field itself. Effective energy generation requires a clear understanding of physics and the mechanisms involved.
Atlantian
Im think of making a device that could harness power from a magnetic field, I hardly know any physics. Now my problem is how or what can I use or make to collect the energy from the magnetic field and turn it into power? and so it can run from a solar panel or wind energy?
please help looking for ideas if possible to make ty.
Atlantian.
Atlantian.
Welcome to PF.
Your questions do not make much sense. What magnetic field? For example, an electric generator converts mechanical energy to electrical energy using a magnetic field: http://en.wikipedia.org/wiki/Electrical_generator
And what does this have to do with solar and wind energy?
Perhaps you could rephrase your questions?
Atlantian.
A static magnetic field doesn't have any power. You can of course take magnetic stuff which is a long way from a magnet, move it closer and extract the power, but once that's used up you have to find more stuff, and you can't put the original stuff back without supplying the energy again, regardless of the level of ingenuity involved in the mechanism.
For an analogy, consider the gravitational field of the Earth. You can't extract power from that either. You can of course let the sun move water to a high reservoir then let it fall under gravity through a hydroelectric plant, but then you are not extracting energy from the gravitational field but rather from the sun.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
