How can I convert 12V DC to 14AC 50Hz for my guitar synthesizer?
  • Thread starter Thread starter SCMatrix
    12v Dc Inverter
To convert 12V DC to 14V AC at 50Hz for a guitar synthesizer, connecting directly to the rectifier input may be feasible, as many devices can handle DC input due to their internal bridge rectifiers. The Boss GR20 synthesizer requires 50Hz for its circuits, which raises concerns about safety when bypassing the original transformer. An expert suggests that while it is likely to work, caution is advised, especially with expensive equipment. Testing with two batteries connected to the appropriate points on the PCB is recommended to verify functionality. Overall, direct connection could eliminate AC hum issues, but careful consideration is necessary before proceeding.
SCMatrix
Hi there :)
I need to build or buy an inverter that transforms 12V DC to 14 AC 50Hz. It's for my guitar sinthetizer, i need to play with it in the street with my 12V batteries. I've tried with an 12V->220AC inverter pure sine (from Velleman) but it introduces to much noise in the guitar.
Any help or ideas I'll be precious.
Thanks,
A. Soares
I'm assuming the instrument comes with a 220 V - 14 V AC transformer adapter and you want to replace it with the inverter, yes? If this is the case, you may be able to forgo the intermediary and connect directly to the battery with an appropriate cable. The reason is that nearly all electronics which take an AC supply have a a bridge rectifier, along with some filtering, to convert that AC to DC. The bridge rectifier can also accept a DC input and because of the way it works, the polarity doesn't matter. The other advantage to this is that it will entirely eliminate AC hum as an issue.
The only possible pitfall I can see is if the equipment uses a transformer (DC causes transformers to saturate) to change the 14 VAC to something else but this is something I've never seen done. There's no point; if you're going to use a transformer anyway, you might as well get one that accepts line voltage and steps it down to what you need. You're pretty safe in trying, I think, as long as you unplug it right away if it doesn't work.
Hi :)
"I'm assuming the instrument comes with a 220 V - 14 V AC "
You're right.
So do you think it's completely safe to connect an 12V battery directly to the input of the rectifier, althought it's an 14VAC input? Just to see if it works,...
By the way it's an Boss GR20 guitar sinthetizer. I've contacted an Boss technician and he told me that the sinthetizer need 50Hz for it's internal circuits/effects, I don't know, i doubt it ...
Thanks, greetings :)
A. Soares
I can't state with complete confidence that it's 100% safe--it's conceivable, albeit unlikely, there's some weird engineering going on in there. I can only state with a high level of confidence that I believe it will work, based on 30+ years of dealing with electronics. I completely understand if you prefer not to take my word, especially if it's an expensive piece of gear!
Worth taking the lid off to find out though.
If the AC input goes to something like this:
These are bridge rectifiers and it is probably OK to run the device off a battery or at least to take it to someone who will check it and tell you for sure.
Hi there :)
And thanks for your help.
I've been with a friend, electronic expert. And he said that my sinthetizer Boss GR20 has DC after the bridge (+12V and -12V).
I'm going to try this weekend with two batteries connected to the right points in the PCB.
Greetings :)
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
