How to Construct a Decagon Using a Protractor and Compass
  • Thread starter cenglish
In summary, the conversation revolves around constructing a decagon, with the OP having difficulty in creating one and resulting in a hendecagon instead. Suggestions are given to construct a pentagon and bisect its edges to draw the decagon, as well as using an enclosing circle and protractor. The issue is narrowed down to execution rather than method.
cenglish
Hi guys, I have been working for a long time and have attempted to construct a decagon but have failed all three times. I know that all the external angles are 144 degrees and they all add up to 1440 degrees. Every time I draw the decagon I come up with a hendecagon. I don't know why I come up with this because I have all of the angles that a decagon consist of. I have searched up YouTube videos on how to create a decagon, but none of them seem to help. I would appreciate if someone could suggest a way to construct a proper decagon. Thank You!
Mathematics news on Phys.org
can't you divide up a circle into 10 equal parts? What would the angle be for each segment? This seems awfully easy unless I'm missing something.
This is a geometry problem, which does not belong in the Intro Physics HW forum. I'm moving it to the General Math forum.
Oh. You have to do this with a compass and a straight-edge?
Construct a pentagon
Bisect the edges
Draw the decagon.
Bisect the edges
minor step missing in here.
Draw the decagon.
I think it is pretty apparent that your angles are not 144 degrees then. What kind of protractor are you using? One of those little plastic ones from the dollar store?
Actually, I made more steps than needed, not fewer, bisecting being harder than simply drawing a line given two points.
Joffan said:
Construct a pentagon which will have an enclosing circle as part of the construction
Find the extra vertices for the decagon on that circle by drawing a diameter from each pentagon vertex
Draw the decagon.
You can bisect the sides of a pentagon, but that there's still a few steps before you get a decagon from that. Granted, they're not hard steps...
Not sure what steps you're talking about that aren't covered by "draw the decagon", simply meaning draw the edges between the already-found vertices.
Unless you have erased the enclosing circle from the pentagon construction? Or drawn the bisectors so short they don't touch the circle?
Yes, I do use the plastic protractor that is provided for me at my school. Would you suggest going out and buying one of my own?
It wasn't a given that the construction of the pentagon included an enclosing circle. He could have constructed with just a ruler and protractor.
No, it's just that your method is fine; it's simply the execution that's flawed.
If you are using a protractor and it's simply an accurate drawing issue:
  • Draw your zero line (wider than the intended shape), mark a centre point
  • Use compasses to draw the enclosing circle for your decagon
  • Put your protractor zero on the zero line at the centre mark
  • Check that 0 and 180 are both on the zero line
  • Mark points at 36, 72, 108 and 144 degrees
  • Draw straight lines (diameters) full across the circle from each marked point through the centre
  • Draw the decagon using the intersecting points on the circle (including the intersection with the zero line)
  • Remove your construction lines.
Related to How to Construct a Decagon Using a Protractor and Compass
1. How many sides does a decagon have?
A decagon has 10 sides.
2. What is the formula for finding the area of a decagon?
The formula for finding the area of a decagon is: Area = (5/2) * (side length)^2 * tan(36 degrees).
3. How do I draw a perfect decagon?
To draw a perfect decagon, use a protractor to measure and mark 36 degree angles at every 36 degrees on a circle. Then, connect the marks to form the decagon.
4. What is the perimeter of a decagon?
The perimeter of a decagon is equal to the sum of all its sides. To find the perimeter, simply multiply the length of one side by 10.
5. Can a decagon be made with any type of material?
Yes, a decagon can be made with any type of material as long as the sides are equal in length and the angles are 36 degrees. This includes paper, wood, metal, etc.
  • General Math
  • General Math
  • Mechanical Engineering
