How can I find the acceleration and position of a chain overhanging a table?
  • Thread starter Thread starter hola
The discussion revolves around a physics problem involving a chain of length 2d and mass 2m that is partially overhanging a frictionless table. The original poster attempts to find the acceleration of the chain as it begins to move and seeks assistance in expressing this in terms of time.
  • Participants discuss the net forces acting on the chain and the implications of mass and acceleration. Some express difficulty in relating acceleration to time, while others explore the effects of changing mass on the system's acceleration.
There are multiple interpretations being explored regarding the nature of acceleration in this scenario. Some participants suggest that acceleration is constant, while others argue that it varies as more of the chain slides off the table. Guidance has been offered on using energy conservation and differential equations to approach the problem.
Participants note the absence of friction and the complexities introduced by the changing mass of the chain as it accelerates. There is also mention of the need for calculus to solve the problem effectively.
hola
Source: PhysicsBowl
A chain of length 2d and mass 2m is placed over a frictionless table such that half of the rope is on the table; the other half dangling, and it is just starting to accelerate. Find its acceleration as a function of time.
I couldn't get this one.
I tried net force = ma
(m+d)g = 2ma; where d represents the mass of the part of the chain that has slipped. But I can't get it in terms of t. Any help?
If I understood correctly the only thing falling is the chain like this:
* = chain
and the "arrow" is the direction that it is falling.
Hint: all mass falls with the same acceleration(on earth).
I know, but I can't solve for a in terms of t.
If there's no friction then the acceleration is constant (same a for every t);
As more of the chain is sliding off the table, the remaining chain will experience a larger force pulling it off the table. Acceleration is not constant
Yes there will be a larger FORCE pulling it of the table but there will also be more mass to pull. Since F=ma the more massive the body is the more force you need to accelerate it. you can also see this mathematicly:
F=ma , in this case the force is mg so:
mg = ma /m
g=a
As you can see, the mass is irrelevant since the more mass you add to the force (mg) the more you need to accelerate it (ma) so the masses cancel out. If there was friction then it would be different cause you'd have more force to overcome the friction and then you'd speed up.
No, the acceleration is not constant. If x is the length of chain hanging over the edge then the acceleration is
[tex]\frac {gx}{2L}[/tex]
The force acting on the chain is the weight of the hanging chain but it's the entire chain that is being accelerated.
You totally right, I was only looking at the mass hanging over the end:(
Were you able to solve this? I tried solving it but I can't. I set up a few relationships, but I think this problem requires some calculus and I'm really weak with that. Can someone help further please?
The solution works out to [itex]x = \frac {L}{2} \cosh \left( \sqrt {\frac {g}{2L}} t\right)[/itex].
how did you do it?
There are two ways to do it. The easier way is to write down an equation expressing energy conservation. It relates the speed of the mass to the length of overhanging mass. Once you have that, solve for v and, since v = dx/dt you can integrate to find x(t).
The other way is to start with the second derivative of x equals gx/2L. It's a little messier but if you're into differential equations you should be able to handle it.
  • · Replies 38 ·
17K
