How can i find the acceleration for this constraint?
17 replies · 5K views
yy205001
What is the acceleration of the 2. kg block in the figure across the frictionless table?
F=ma
g = 9.8ms^2
as long as they are in the same system, i think they have the same acceleration
F=ma
g = 9.8ms^2
You'll have to show more effort. What is the constraint imposed by the pulley system on the relative motions of the blocks? Did you draw FBD's for both blocks? What are the resulting force equations?
yea, i drew FBD for both blocks. In the x-direction, the resulting force is T. And in the y direction is (m(1kg)g-T).
Okay. In your diagram you depict two "T" forces acting on the 2kg block, so why do you say the resulting force is T? How are the accelerations of the blocks related?
sorry, it should be 2T. Are they having the same acceleration, this is my main problem.
The rope and pulley system place a constraint on the motions. If the 1kg block moves down a distance d, how far will the 2kg block slide?
will it slides a distance d as well??
Nope. Do a rope segment length calculation. Remember that the rope's total length is constant.
yea,i got d/2. Is it correct??
Yes, that's fine. That then will be the constraint connecting the motions of the blocks. It will apply to distance moved, velocities, and accelerations.
i still cannot get it
gneill, do you mean the acceleration of the hanging mass is twice the acceleration of the mass on the horizontal surface??
Yes, it must be due to the constraint...
Convert your FBD force equations to acceleration for each block. Use the constraint equation for acceleration to solve.
In the x-direction, the Net force is 2*T.
Let a1 be the acceleration of the mass on horizontal surface,
a2 be the acceleration of the hanging mass.
"F=m*a", so:
2*T = 2*a1
T = a1
In the y-direction, the Net force is mg-T, where m is 1kg,so:
m*g-T = m*a2
where T = a1
→m*g-a1=m*a2
Then,sub in a2=2*a1
m*g-a1=m*2*a1
So, i can find out the acceleration of a1, thus find a2?
"F=m*a", so:
2*T = 2*a1
T = a1
Tension has units of Newtons (force). It is not an acceleration (m/s2).
Use the relationship F = ma that you've written to turn the net force into an acceleration, hence a = F/m. So that would make a1 = ?
m*g-T = m*a2
where T = a1
→m*g-a1=m*a2
Then,sub in a2=2*a1
m*g-a1=m*2*a1
Again you're mixing units. Forces (like m*g) are not accelerations (m/s2).
Just write the accelerations for each block separately at first; Don't try to apply the constraint until you have those expressions. You should have:
a1 = (something in terms of m1 and T)
a2 = (something in terms of m2 and T and g)
After you have them you can use the constraint equation to eliminate one of the accelerations...
yes, i got the correct answer finally, thank you so much!
