How Can I Improve My Spark Gap Switch for High-Speed Photography?
The discussion revolves around improving the design and reliability of a spark-gap switch, specifically a trigatron, for high-speed photography applications. Participants explore various electronic components and configurations to achieve reliable triggering for capturing fast events.
  • Experimental/applied
  • Desmond describes his initial attempts at creating a spark-gap switch for high-speed photography, detailing issues with fuse blowouts and reliability.
  • Some participants suggest using a hot shoe switch directly instead of relying on the current through the flash capacitor, proposing that this could simplify the triggering process.
  • There are recommendations to incorporate an opto isolator to trigger a triac, with an emphasis on making the triac easy to replace due to potential fuse issues.
  • One participant mentions successfully using an SCR rated for high voltage and current to ignite gunpowder, indicating a different approach to triggering but expressing interest in perfecting the trigatron design as well.
  • A humorous suggestion is made about the trigatron potentially being able to take its own picture if it works effectively.
Participants do not reach a consensus on the best approach to improve the trigatron design, with multiple competing views and suggestions presented throughout the discussion.
Participants express uncertainty regarding the reliability of different components and configurations, as well as the limitations of their current designs. There are unresolved questions about the optimal triggering method and the performance of various electronic components in this context.
DesmondD
Hi everyone , this is my first post here :) . I am an auto electrician , my hobby is photography. I am interested in high speed photography and have invented a new form of photography in a way . I call it 'superspeed photography' . It involves taking a picture of something that is triggered by the act of taking the picture .
My early attempt involved a water balloon being burst by a needle pushed into it by a solenoid in series with the flash capacitor ...
Now I am busy building a spark-gap switch or 'trigatron' as I am told it is called .
It is proving difficult to get reliability . With the first design I drilled a hole in the conductor and ran an insulated wire down the middle so that when I take a picture my camera flash triggers a 40 000 volt spark down the centre of the contacts and causes the 320 volt capacitor to jump the gap through the ionized air .
It blew a 10 amp and a 20 amp fuse on two of my attempts ...
a 40 amp fuse caused the electrode tip to blow off rather and it is proving difficult to get a reliable switch each time .
This is a 3.5 amp fuse blowing with 320 volts photographed at 1/1000th sec - the act of pressing the shutter is what triggers the spark and 'explosion' ...
Tonight I tried a different version based on some pictures I have seen of a trigatron - it isn't switching though the contacts should last much longer this time if I get it to work ...
I've put some light bulbs in series with the switch to quieten the noise of fuses blowing in my garage though I'm wondering if they just can't light up fast enough for the quick switching action I would get ?
Any advice on perfecting this design for reliable switching and hopefully some really good photos would be appreciated :)
Thanks , Desmond .
1100 views and no replies yet? Does anyone have any answers for me?
here's my last design.
I would probably have used the hot shoe switch directly rather than the current through the flash capacitor. Then the rest is electronics and depends on what exacty you are trying to trigger. Perhaps use an opto isolator to fire a triac or something.
PS: Make the Triac easy to replace if you are trying to pop fuses with unlimited current.
I eventually wired up an SCR to the hotshoe trigger circuit, the one I'm using is rated at 800volts and 3800 amps surge.
It dumps the capacitor across a thin piece of wire and ignites the gunpowder quite nicely.
However, I would still like to perfect the Trigatron just for fun:)
If you get it working you could get the trigatron to take it's own picture.
  • · Replies 19 ·
12K
