How can I interface a DFIG in a multi machine environment?
The discussion centers on the appropriate reference frame for modeling and controlling a doubly-fed induction generator (DFIG) in a multi-machine environment, specifically within a wind farm. It is suggested that using an infinite bus as the reference frame simplifies modeling, despite the need to account for phase differences due to slip in the DFIG compared to synchronous generators. The importance of designing control schemes that remain effective despite changes in the surrounding system is emphasized, advocating for performance checks against an infinite bus. The conversation highlights that all phase angles are relative, meaning the choice of reference point does not alter the relative angles. Overall, the focus is on achieving robust control strategies for DFIGs in complex networks.
SherLOCKed
Which will be my reference frame while modelling and control - the reference machine in the network or the network bus itself?And if so how do i relate the dfig to this reference frame?
By DFIG, do you mean doubly-fed induction generator, as in a wind generator?
Modeling can usually succeed with any choice of reference. However, choosing the network bus to be an infinite bus (voltage magnitude=100%, and phase angle=0), is both useful and often simplest.
Likes SherLOCKed
Thanks for your reply. But Instead of a single machine infinite bus,I needed to connect a dfig in a wind farm which already consists of synchronous generators and a few dfig's. So the synchronous machines will have a zero phase angle with the network bus but the dfig must have some phase difference with the bus due to the slip, isn't it? If yes, how do I find that angle via modeling?
It would probably be wise to design the control ls as if it was supplying an infinite bus, then check the performance against the actual system. A control scheme which must change any time something in the neighborhood changes, is not very good. You want controls which work well within a reasonable range of nearby connected devices. Performance against an infinite bus is a good way to approach that.
Your question was about the reference. All phase angles are relative. No matter which point you choose as reference, the relative angles are the same.
Good luck
Thank you so much :)
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 31 ·
