How can Newton's Laws be applied to the motion of a bus and a person on it?
Newton's First Law explains why a person is thrown back in their seat when a bus accelerates; the person continues at rest until a force acts on them. When the bus accelerates, the person remains stationary until they collide with the seat, at which point Newton's Third Law comes into play. The bus exerts a force on the person, causing them to accelerate forward, while the person simultaneously exerts an equal and opposite force on the bus. In the case of a rocket taking off, Newton's Third Law is also applicable, as the rocket pushes exhaust gases downward, resulting in an upward force on the rocket. Overall, both laws illustrate the interaction of forces during acceleration and motion.
ThomasMagnus
Hi there, I have two simple physics questions.
One day I was on the bus, and began to wonder why I kept getting thrown to the back every time the bus accelerated. Which one of Newton's laws can be applied to this?-if any.
Another question is: When a rocket takes off, it applies a force in the opposite direction. Can this be described as Newton's 3rd law: F₁=-F₁
Thanks for the help!
Newton's 1st law might shed some light. You tend to keep moving at the same speed in a straight line unless a force acts on you. When the bus accelerates, you tend to stay put until something pulls or pushes you along with the bus.
Yes, Newton's 3rd law applies. The rocket exerts a force on the exhaust gases it expels, which in turn exert an equal force on the rocket.
Could Newton's third law be applied to the bus? The bus exerts a force forward and I fly back?
1.Newtons first law 2.yes
Not until you hit the back of the seat. When the bus accelerates, it doesn't apply a force to you. You simply crash into it. However, when you do hit the seat, you will apply a force against the bus and the bus will exert a force on you, but not before that.
Suppose you and the bus are at rest at 0 m/s and you are sitting forward in your seat. When the bus accelerates, it begins to have a positive velocity while you still have 0 velocity since the force of the tires and engine are acting on the bus but not you. Soon after, the bus seat will hit you. At that point, the bus acts with a force on you that makes you accelerate until your velocity matches the bus velocity. Due to Newton's 3rd law, you also exert a force on the seat in the other direction decreasing the acceleration of the bus. However, since the bus is powered by a giant engine and you are very small compared to the bus, the force acting on the bus due to you hitting it is not noticable to the bus.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
