How Can Ohm's Law Help Determine Current in a Parallel Circuit?
This discussion focuses on applying Ohm's Law to determine the total current in a parallel circuit containing three resistors: 3Ω, 6Ω, and 9Ω, with a total voltage of 12V. Participants clarify that the equivalent resistance for resistors in parallel is calculated using the formula 1/R_total = 1/R1 + 1/R2 + 1/R3, which leads to a total resistance of 2Ω. The total current can then be calculated using Ohm's Law (I = V/R), resulting in a total current of 6A.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of parallel circuit configurations
  • Ability to calculate equivalent resistance for parallel resistors
  • Familiarity with basic electrical units (voltage, current, resistance)
  • Learn how to calculate equivalent resistance in complex parallel circuits
  • Study the relationship between voltage and current in parallel circuits
  • Explore practical applications of Ohm's Law in real-world electrical systems
  • Investigate the effects of varying resistor values on total current in parallel circuits
Students studying electrical engineering, educators teaching circuit theory, and anyone interested in understanding the principles of electrical circuits and Ohm's Law.
Zoey
Apply Ohm's law and the nature of parallel circuits to determine the total current in a parallel circuit with three resistors: 3Ω, 6Ω, and 9Ω, respectively. The total voltage in the circuit is 12V. Explain your reasoning.
[/B]
Ohm's Law
[/B]
I tried to plug the values into Ohm's law, but I don't think that is how I am supposed to go about this.
I am not asking for someone to give me the answer outright, just a place to start here!
All answers will be appreciated! :wink:
It is necessary to show your working. Did you calculate their equivalent resistance first or did you directly apply Ohm's law? Both ways work fine.
cnh1995 said:
It is necessary to show your working. Did you calculate their equivent resistance first or did you directly apply Ohm's law? Both ways work fine.
Hi,
I just tried to apply Ohm's Law directly. I realized it wasn't going to work, because I have more values than are in that formula. But here is as far as I got.
First I added up all of the Ohms and got 18Ω. Then, I plugged it into the formula,
V/R = 12/18 = 0.6666666667
And I guess that could be right, I just figured that because of how I went about adding up the Ohms that it wasn't.
Thanks!
Zoey said:
Hi,
Why would you add the resistance values together when you are told specifically that the resistors are in parallel?
Do you not understand what "parallel" means in this context?
As I said, I did not think I was doing it correctly. It was simply me attempting to go about the problem, not really having any idea how. I guess what I am really asking is how I would use this information in a formula.
Have you studied the concept of equivalent resistance of a series/parallel network?
No. That is what I was trying to get a grasp of.
Ok. What do you understand from the fact that they are in parallel?
I understand that by parallel it means there are multiple resistors that are side by side next to each other. What I am not understanding is how to apply this information to use it in a formula..
What can you say about voltage across parallel components?
I think I have figured it out, using the formula for total resistance.
= 3x6x9/3+6+9 = 162/8 = 9
Then I used the formula for total current:
12/9= 1.33333333333333
No. The equivalent resistance of parallel combination of 3Ω, 6Ω and 9Ω is not 9Ω.
The formula in your image is true for only two resistors in parallel.
Oops I think I used the wrong formula. Here is the formula for multiple resistors:
Which would make 18, correct?
So then 12/18 is 0.666666667.
Have you studied the theory behind series and parallel components in a circuit? Do you understand what happens to voltage or current when components are in series or parallel?
No. Equivalent resistance of resistances in parallel is less than the least of them.
Thank you for trying to assist me with this, and sorry if I don't seem to be understanding this. Could you tell me what formula is supposed to be used here then if it wasn't the one I used above?
Well, the formula in your above post is correct but it doesn't give 18 ohm. Try again using that formula.
What does 1/Rn stand for/mean though? Because all of the values I have are the resistors and the voltage...
1/Requivalent...
cnh1995 said:
1/Requivalent...
Does that mean you would add all of the resistors + the equivalent of all of the resistors? So then it would be 36?
I will give you a couple of hints.
One. For resistors in parallel the resistance of the combined resistors is less than the smallest resistor.
Two. The smallest resistor is 3 ohms. The current through that resistor at 12 volts is 4 amps.
Therefor the parallel resistance of all the resistors is less than 3 ohms, and the combined current will be greater than 4 amps.
$$\frac{1}{a}+\frac{1}{b}+\frac{1}{c}≠\frac{1}{a+b+c}$$
You should review how to add fractions together.
You do not need the formula for the equivalent resistance. All resistors are connected directly to the terminals of the battery. What is the voltage across each resistor? Apply Ohm's law to calculate the current flowing through resistors R1, R2, R3, then add them up.
If you can calculate total resistance in parallel circuit. Then you are getting closer to the solution.
The other step is to know what is the total voltage in circuit with the parallel resistors.
Then you can find the total currwnt in circuit using ohms law.
The question only asked what is the total current. It is not needed to calculate each current at each resistor. (Because it was not asked to do so)
However that could still be done if you wanted to calculate that way... it would simply show that the current varies in those individual resistors compared to other resistors (in this scenario all resistors were 3 ohms 6 ohms 9 ohms.)U=RII don't have expert qualifications to give advice but I was doing these problems yesterday myself hehe...
Very true. The problem doesn't ask for the current through each resistor, but it's easy to calculate and, when you simply add the three currents together, you have your answer.
if you know for sure...
Do you actually get the total current, by using the ohms law, When we already know the total resistance and the total voltage in parallel circuit
In other words does the total current and total resistance yield us the total current ?
Yes. Absolutely. But if you want to find the answer quickly, you may make intermediate calculations that yield the solution indirectly.
That's something of a tautology. I think you meant to ask if the total resistance and the voltage drop yield the total current.
Instead of hunting for the right equation, try understanding the situation. This is what you'll be tested on.
In a parallel circuit, each item has the same voltage across it. Use that, and ##V=IR## to find the answers.
Just to clarify... both approaches work. You can either work out the equivalent resistance and then the current OR calculate the individual currents and add them up.
I encourage you to do it both ways to prove it to yourself that the answers are the same.
The formula for the equivalent resistance follows from Ohm's Law, and from the fact that the voltage is the same U across each parallel resistors. So the individual currents are I1=U/R1, I2=U/R2,I3 =U/R3 ... The net current flowing out from the battery is the sum of all currents, I=I1+I2+I3 = U/R1+U/R2+U/R3. Pull out U : I=U(1/R1+1/R2+1/R3) The expression in the parentheses is the reciprocal of equivalent resistance for the parallel resistors.
1/Rp = ∑1/Ri, and I=U/Rp.
  • · Replies 42 ·
  • · Replies 18 ·
