How can rotation with same phase be possible?
  • Thread starter Thread starter akashpandey
    Phase Rotation
The discussion centers on the concept of the moon's rotation and its consistent phase as observed from Earth. The moon rotates on its axis while simultaneously orbiting the Earth, which results in the same face always being visible. This phenomenon occurs due to synchronous rotation, where the moon's rotational period matches its orbital period of approximately 28 days. The phases of the moon are determined by the relative positions of the Sun, Moon, and Earth, not by the moon's rotation. The thread was ultimately locked due to redundancy, as similar questions had been previously addressed in another discussion.
akashpandey
How can we calculate the rotation without seeing change of phase of object like in case of moon,we see the same phase of moon but how it can be rotating.
So rotation without change of phase is possible if yes or no than how and why ?.
The moon rotates around the Earth. If it did not rotate on its axis, how could it keep the same face towards the Earth?
So rotation depends on what face you are seeing?
Or moon's rotation is different kind of rotation?
The phase of the moon depends on the angle Sun-Moon-Earth...
This changes with a cycle lasting about 28 days because that's how long the moon takes to orbit the earth.
The phase of the moon does not depend on the rotation of the moon about it's own axis. The light and dark areas are not painted onto the surface of the moon :-)
Likes russ_watters
why are we discussing this again ?
in your other thread in the astronomy section
https://www.physicsforums.com/threads/spin-or-rotation-of-moon.907744/
this was all answered for youDave
Please do not create duplicate threads. If there is anything you still don't understand, just ask in the thread you already have. Thread locked.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 47 ·
  • · Replies 19 ·
