How can you accurately find the initial velocity of a toy gun?
To accurately find the initial velocity of a toy gun while disregarding air resistance, using a ballistic pendulum is recommended as it provides a repeatable and precise measurement. Observing the maximum height achieved by the pendulum after the toy gun fires can also yield useful data, applying the principle of conservation of energy. Additionally, utilizing a digital camera capable of slow-motion filming can help capture the projectile's motion, although resolution may be limited. Proper technique in these methods is crucial for accuracy. Overall, the combination of these approaches can effectively determine the initial velocity.
RobSGo
Disregarding air resistance, how could you find an accurate number for the initial velocity of a toy gun?
Ballistic pendulum? Fire it into a pendulum so that it sticks and see how high the pendulum goes?
Welcome to Physics Forums!
Welcome to the PF.
Why would you disregard air resistance? Do you want to know Vo or not?
Welcome to the PF.
The exit velocity is the velocity, whatever you are firing into. I think, by "disregarding air resistance" he refers to the measurement method. If he is, then observing the maximum height achieved (KE=GPE) would be a way forward (or up haha). The ballistic pendulum would be more accurate and repeatable, once he's got his technique right.
The pendulum is probably the best way.
But you can also check if your digital camera supports slow motion filming. Some cameras below 500$ can film at more than 1000fps, which should be enough for a "toy gun". The pixel resolution is usually low, but sufficient if you place the camera right next to the muzzle.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
