How can you simplify exponents involving fractions and roots?
  • Context: MHB
  • Thread starter Thread starter CSmith1
    Algebra
The discussion focuses on simplifying exponents involving fractions and roots, specifically using the example of \(32^{2/5}\) and \(32^{1/5}\). The correct simplification leads to \(2^2\), which equals 4, by recognizing that \(32 = 2^5\). The participants emphasize the importance of notation clarity, recommending the use of LaTeX or clear bracket notation for better understanding. A key takeaway is the mnemonic "power over root" to remember the process of handling fractional exponents.
  • Understanding of fractional exponents
  • Familiarity with roots and their properties
  • Basic knowledge of exponent rules
  • Ability to manipulate expressions using LaTeX or similar notation
  • Learn about simplifying expressions with fractional exponents
  • Study the properties of roots and their applications in algebra
  • Explore the use of LaTeX for mathematical notation
  • Practice problems involving exponent rules and simplifications
Students, educators, and anyone looking to improve their understanding of exponents and roots in algebraic expressions.
CSmith1
is this correct?
1.) 32 2/5(32 1/5) ^2=(5 SQUARE ROOT 32)2
=5(SQUAREROOT 2X2X2X2X2)2
=(5 SQUARE ROOT )2
=5 SQUARE ROOT 2 X 5 SQUARE ROOT 2
=25 (2 SQUARE ROOT 2)
=50 SQUARE ROOT 2
Mathematics news on Phys.org
CSmith said:
is this correct?
1.) $32^{2/5}$$(32^{1/5}) ^2$=(5 SQUARE ROOT 32)2
$(\sqrt[5]{32})^2$
$= (\sqrt[5]{2 \cdot 2 \cdot 2 \cdot 2 \cdot 2})^2$
Notation aside you're correct up to here
=(5 SQUARE ROOT )2
=50 SQUARE ROOT 2
You've lost me here though. You have $(\sqrt[5]{2^5})^2$ which is the same as $((2^5)^{1/5})^2$ which cancels down to $2^2$
A simpler way IMO is to note that $32 = 2^5$ (as you did). That leaves you with $(2^5)^{2/5} = 2^{5 \cdot 2/5} = 2^2$Your notation is very tricky to follow. Please use Latex or "^" together with brackets next time to make it easer to follow.
I don't know how you were taught to approach these, but the short way to remember a fraction as an exponent is "power over root". The top number of the fraction is a power, so you should multiply the number together that many times. The bottom number is a root, so you need to find a number that multiplied together that many times gives you the original number. You can do it in either order, but you do one at a time. You have 32 to begin with so it's logical to take the root first because that will be a smaller number than 32. If you apply the power first then the result will be quite large and less easy to work with.
[math]32^{\frac{1}{5}}=2[/math] because $2 \cdot 2 \cdot 2 \cdot 2 \cdot 2 = 32$.
So now we've applied the root and got 2. Now we apply the power and get $2^2=4$ and we're done. Again you can choose the order in which you calculate this so take a second to consider both options and choose the one that has the easier numbers to work with.
  • · Replies 41 ·
  • · Replies 22 ·
  • · Replies 28 ·
