How circuit breaker electrical system clears ground faults.
The discussion revolves around the operation of circuit breakers in electrical systems, specifically regarding how they clear ground faults at a transformer. Participants explore the configuration of circuit breakers and the paths fault currents take during such events, examining both theoretical and practical implications.
  • One participant questions how fault current from the X2 terminal at the transformer can trip the circuit breaker, expressing confusion about the current's path.
  • Another participant asserts that the fault current does indeed pass through the circuit breaker, completing the circuit through the load and ground wire back to the transformer.
  • A question is raised about why the fault current would choose the path through the load resistance when a lower-resistance path is available during a ground fault condition.
  • Clarifications are provided regarding current flow under normal and ground fault conditions, indicating that most current flows through the ground wire during a fault.
  • One participant acknowledges a misunderstanding regarding the situation depicted in the initial post, clarifying that the fault occurs at the transformer enclosure rather than at the load.
  • Another participant notes that if a ground fault occurs at the transformer, the circuit breaker may not trip, but the fuses protecting the primary winding of the transformer would open.
  • A hypothetical scenario is proposed where the bonding configuration is altered, questioning whether it would provide the same level of protection.
Participants express differing views on the behavior of fault currents and the effectiveness of circuit breakers in various configurations. There is no consensus on the implications of the bonding configurations or the specific paths taken by fault currents.
Participants reference specific configurations and paths of fault currents, but there are limitations in the clarity of the diagrams and the assumptions made about the system setup. The discussion is also influenced by the varying interpretations of the electrical system's behavior under fault conditions.
newbie2231
Hi I am taking generals now but I will eventually take EE degree. I am studying electrical systems now. Can somebody help me on system configuration regarding circuit breakers clearing ground faults?
In this picture (the bottom figure), if X2 faults at the transformer, would the fault current ever trip the breaker? I know that it should but I just don't see how. The fault by X2 in the picture will travel through a bonding jumper (the short green horizontal piece between the transformer and the disconnect panel), then to the disconnect, then eventually to the X0 of the transformer. The current will cycle like that but will not travel through the breaker. From reading the web page where this picture came from, I know the bonding jumper will make the breaker trip when the X2 faults at the transformer. But I just don't see how. Any help is appreciated.
The fault current DOES go through the CB. The current will go from the X2 terminal to the CB, to the load, to the ground wire and then back to the center tap of the transfromer. This completes the circuit.
Why does the fault current take the path that has the load resistance when another path with virtually no resistance now became available?
I'm not sure what you mean. Under normal condition, current flows through the load (represented by the resistor symbol). Under a ground fault condition, current flows through the ground wire. In the picture below, I drew the path of the ground fault current. Very very little current will flow through the load during a ground fault because the ground wire has almost no resistance.
My apologies. I used the picture for describing the involved equipments but not for the situation illustrated in the picture. In my situation, the fault happens not at the load, but at the transformer enclosure.
So the pictures don't go with the question in first post?
Circuit breakers protect downstream equipment...
Dave90 did a good job with the pictures given.
I see. If a ground fault occurs at the transformer, then no the CB will not trip. However, the ground fault will trip the CB or fuse ( Not shown in your picture) that protects the primary winding of the transformer.
So the primary winding's fuses open. Okay I see. Now, what if I got rid of the green wire that electrically bonds the transformer enclosure to the disconnect panel. And then I bond the transformer enclosure to the X0. Would that not produce the same protection, same result?
  • · Replies 38 ·
9K
  • · Replies 42 ·
  • · Replies 79 ·
  • · Replies 23 ·
