How come projectiles have parabolic path?
  • Level: High School
  • Thread starter Thread starter xAxis
    Path Projectiles
10 replies · 16K views · last reply
xAxis
I wonder no one posted this question before. I understand we don't take the Earth curviture into equation of motion, but still projectiles do have parabolic trajectory.
Doesn't parabolic trajectory imply unbounded orbit?
The parabolic trajectory assumes that the gravitational force on the projectile is constant. For everyday objects, like a ball thrown into the air, this is an exceedingly good approximation. However, if you really want to be exact about it, you would have to consider that the force on the projectile actually decreases (imperceptibly slightly) as it moves upward and increases again as it comes down. If you include this, you'll find that the trajectory is really a very short segment of an ellipse.
Ah, but for a geosynchronus orbit, g does not change at all, yet we get a circular solution to the motion of a geosynchronus satellite!
I would argue that it is the fact the variation in the DIRECTION of g, and not it's magnitude that results in elliptical and circular solutions. In other words, we don't get circular/elliptical solutions because we assume the direction of g remains constant.
If we assume the direction of g can vary (like we do for circular motion) than we can arrive at the said elliptical/circular solutions.
Claude.
Claude.
In fact, to get elliptical solutions you need both. [tex]\vec{g}[/tex] must always point to one particular place and it must vary as [tex]\frac{1}{r^2}[/tex], with r the distance to that point.
You can even ignore all the points made above and still solve the paradox.
If you were very, very careful to measure the (apparfently parabolic) trajectory of a ballistic object, you would discover that it is actually a segment of an ellipse with its focus 4000 miles away - at the center of the Earth.
If the Earth were magically replaced with a black hole of 1 Earth mass, the object would follow an elliptical orbit (well, if you ignore the gradient).
Vf= Vi + at
Acceleration is a "squared" quantity.
The graph of a square is parabolic
Agnostic said:
Vf= Vi + at
Of course, the gravitational gradient around the Earth is spherical, and thus would require a graph with polar coordinates. Thus making the path an ellipse...:biggrin:
the Newton's law of gravitation could result in a parabolic path (when potential energy=kinetic energy and when some other conditions are meet). In fact, the general solution is all conic sections as a result of the solution of the two body problem.
Usually, near the surface of the earth, you approximate the local surface of the Earth with it's tangent, or actually on infinite plane, and then assume that the gravitational force is prependicular to this plane. And as it was pointed out, the Newtons gravitational force is spherically symmetric and the force acts to the radial direction. And this is needed for the Kepler's laws.
WHen i first looked at this thread i thought "hey that's something easy," but then got confused when reading other answers :P
That makes sense. Earth is big:smile:
