How Deep Does the Fish and Its Image Appear in a Pool?
In a discussion about the apparent depth of a fish in a swimming pool with a mirror at the bottom, participants explore how to calculate the perceived depth of both the fish and its image. The real depth of the fish is 0.05 meters, while the pool's total depth is 2.00 meters. The conversation emphasizes the relationship between real depth and apparent depth due to refraction, suggesting the use of specific formulas for accurate calculations. One participant expresses uncertainty about the calculations but seeks clarification on the concepts involved. The discussion highlights the need for understanding refraction principles to solve the problem effectively.
oddwolf
A 2 meter deep swimming pool is filled with water. A mirror is placed at the bottom and a small fish swims 5 cm (0.05m) below the surface. If you look at the swimming pool from above, how deep does the fish appear to be (a), and how deep does it's image appear to be (b)?
a1 = 0.05 m
a2 = 2.00 m
n_air = 1
n_water = 1.33
n1/a1 + n2/a2 = (n2 - n1)/r
Not so sure with (a), but without using the formula or anything on (b), my intuition tells me that the mirror-image should be 15+15+5 centimetres below the surface. Would really appreciate some help with (a) and some input.
Thanks in advance!
Is any spherical surface mentioned in the problem?
ehild
The only hint my book gave me is to use the formula for refraction in spherical surface.
And you can derive hell lot of equations from what ehild provided you. :D
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
