How did the big bang ever stop being a black hole?
The discussion centers on the transformation of the universe from a potentially black hole state to its current expanding form. Participants argue that the uniform distribution of mass and energy in the early universe prevented it from being a black hole, as the gravitational forces were balanced. The concept of Schwarzschild radius is debated, with the consensus that it applies to static black holes, not an expanding universe. The role of inflationary energy is highlighted as crucial in overcoming gravitational collapse. Ultimately, the early universe's conditions and the dynamics of expansion are key to understanding its evolution away from a black hole state.
AdrianMay
The title says it all. With all that mass in such a small space it must have been one, but then everything would have to stay inside it. If it was still a black hole we'd have a closed universe but nobody believes that anymore. Does this mean the whole universe started out as Hawking radiation or what?
Adrian.
Space news on Phys.org
Adrian.
Well, the thing that makes it not a black hole is the distribution of mass: the mass in our universe was always distributed rather smoothly. And the equations of motion for such a universe simply aren't the equations of motion for a black hole.
So was it a black hole during the first few nanoseconds when all that mass was packed into a space the size of a golf ball?
That's actually irrelevant. If you compare the mass of the current universe that lies within one Hubble distance (c/H_0), you get a Schwarzschild radius that is the same Hubble distance (and if you include more of the observable universe, the Schwarzschild radius gets larger faster). If our universe were a "black hole" then, it would still be one now.
Chalnoth, I thought the universe was a black hole interior solution, but with the clock running backwards--so a white hole.
I don't think that's accurate. It's sort of similar in some respects, but the primary difficulty that I can see with it is entropy. The entropy of our universe has been increasing continuously. The entropy of a white hole decreases in time (which is also a statement that a white hole is unphysical).
Yes, well, I suppose I should think less and compare metrics more. Although the energy rather than the entropy would determine the metric, it seems.
The solution for the whole Universe is simply different from a solutions of White/Black hole.
The main difference is the momentum matter has in the expanding universe. Gravity depends not only on mass!
I think that this is a very key question.
In the standard model, the very early universe is far more dense and massive than any supermassive black hole, in fact all of them put toether and more. So how does matter overcome the gravitational pull to get beyond the Schwarzschild radius? Do we need matter to exceed the speed of light to do this? Would relativistic mass make it more difficult for matter to ever escape?
It seems that we need another type of inflation energy to make inflation happen otherwise we would be left with a permanent enormous black hole until this energy was provided in some way?
I heard a theory that before the forces broke apart the inflation speed exceeded the speed of light.
I remember hearing or reading that somewhere but I do not remember where or when.
Again, Schwarzschild radius is calculated based on the assumption that mass does not have significant momentum. In early Universe this assumption is not correct. This is why the GR solution for the whole universe is different.
Dmitry, this is probably something that I am just going to have to accept. One thing that I learned about black holes is that nothing, not even light itself (zero rest mass mass traveling at the speed of light), could ever escape from a black hole.
Likes zsawaf
The black hole solution is static. The expanding universe solution is not static. Comparing apples and oranges here, people.
Likes 1oldman2
Nicksauce, probably I am getting stuck trying to imagine one psuedo infinite overcoming another psuedo infinite!
By assuming the existence of a Schwarzschild radius, you have already made an error. The Schwarzschild radius is a feature of the static (or stationary) black hole solution. An expanding universe solution has no such feature.
Why is this? The matter is still momentarily at least the size of a singularity with pseudo infinite density. Sorry I am not being argumentative, I just don't understand.
Okay, this isn't the correct way to think about it, but it might help you out anyway.
The event horizon isn't dependent on density, but rather the mass to radius ratio. We need
M/R = \frac{c^2}{2G}
Now let's see what we get for M/R for our universe. Note that M/R = \rho\,R^2 We can estimate R as the Hubble radius
R \sim \frac{c}{H}. From the Friedmann equations, in a radiation dominated universe, we have H=H_0(\sqrt{\Omega_R}a^{-2}), so R = \frac{ca^2}{H_0\sqrt{\Omega_R}}. Meanwhile, \rho=\rho_c\Omega_ra^{-4}, so we get \rho\,R^2 = \frac{\rho_cc^2}{H_0^2}. Putting in the value of \rho_c, we get M/R = \frac{3c^2}{8\pi\,G}
And since 3/8pi < 1/2, we never get the condition, for the Schwarzschild radius.
Because in GR it is not the mass that is creating gravity. You always think just about 'how much mass you have in some volume'.
It seems to me there are two separate questions
1) black hole inside the universe
2) the whole universe as one big black hole
On the first the thing is the matter/energy is so uniformly distributed that even though a sphere may contain enough stuff to make the escape velocity at the surface be greater than c the stuff outside the sphere contributes an equal and opposite force and the net force is near zero (no black hole).
On the second well I guess we have two cases the universe is open and the universe is closed.
If open then a photon can travel arbitrarily far from some reference point so it does not seem like a black hole. It seems to me for that to work there would need to be matter/energy beyond the observable universe. This gets confusing to me.
If closed then a photon can only go around in circles. Do we want to call this a black hole interior? Darned if I know.
Hi nicksauce,
I know what m, r, c, G, rho (and even pi) are, but what are H, H0, Omega, a and rho-c?
Adrian.
AdrianMay said:
Hi nicksauce,
Adrian.
First, a is the scale factor of the universe. By convention, typically a=1 is defined as now. So a=0.5 would be when galaxies in the universe were, on average, half as far apart as they are now. The expansion rate H is then defined as:
H(t) = {1 \over a}{da \over dt}
For nearby galaxies, where we can neglect the fact that H changes over time, this definition of H gives it the property that the recession velocity of a galaxy is simply given by v = Hd, with d being the distance to the galaxy. The current Hubble expansion rate is then defined as H_0.
\rho_c is the amount of matter/energy density, for a given expansion rate, that is required to give a universe with flat space. It is defined as:
\rho_c = {3 H^2 \over 8 \pi G}
Lastly, \Omega is a given matter or energy density of the universe divided by \rho_c.
People are saying I should include other energies besides mass. Fair enough, but that would only seem to make the problem worse.
I also don't understand why momentum means we can't talk about a Schwarzschild radius. The stress-energy tensor is going to be bigger, so does this mean its other elements are actually opposing the effect of the 0,0 element?
I believe pressure contributes to black hole collapse, so we'd be relying on the off-diagonal elements to save us. Is it something to do with a determinant? I never understood those field equations anyway, but it seems to me that if they were right we wouldn't need dark matter.
The reason the early universe wasn't a black hole and didn't become one was because of the distribution of matter/energy/pressure. It was uniform throuought all of space and therefore there was no concentration to create an interior event horizon. It's very much like the way there is no gravity at the center of the earth.
The early universe may have packed everything into a golf ball but there's nothing outside the golf ball. No concentration, no black hole.
Hi Antiphon,
That makes sense actually. I suppose we're talking about a closed universe in the sense that you'd end up where you started if you kept going in the same direction, except that by the time you got back more space would have appeared in between, and you'd need to exceed the speed of light to catch up. Right?
This argument sounds quite different from either of nicksauce's though.
Nicksauce Thanks for reply
you were talking about Hubble radius. Does the Hubble radius not also come close to reaching a singularity at 10-32secs? This is the condition I am referring to where we have the entire universe apparently almost the size of a singularity and hence the highest density the universe has ever encountered. Something I am not getting here, because this must surely be enough matter to form a black hole under normal conditions at least. Unless inflation energy prevents this.
Nicksauce, after review of Hubble radius I think my reply was hasty.
Roughly speaking, the Hubble radius is the radius of the observable Universe. So what was the radius of the observable universe at t=10-32 secs, or if this is not known, then some point a short time later?
Is the fact that such a high density state did collapse to form a black hole because the same high density existed everywhere and all around resulting in the same forces in every direction?
Well, the observable universe is a few times the Hubble radius.
That depends critically upon the rate of expansion at early times, and when you pick "t=0" to be. So it's not a well-defined question, as near as I can tell.
I presume you meant didn't. But yes, that is what makes the FRW universe work. One thing I haven't done, but might be interesting, is see what happens when you have, for instance, a uniform spherical distribution of matter out to some very large radius (much greater than the Hubble radius), so that the Schwarzschild radius for the total mass is larger than the size of the matter distribution, and see how it evolves in time as given by General Relativity.
Tanelorn said:
So what was the radius of the observable universe at t=10-32 secs, or ...
For me, the problem is how did time ever get past 10e-32 sec, given the assumed energy density "in the beginning".
Discussions of the first three minutes/seconds/femtosecs seem always to skip over this hurdle too easily.
Well, the average density is irrelevant to the question. The current universe is no more or less susceptible to this issue than the early universe was.
  • #31
Chalnoth, this would be an interesting though experiment/computer simulation. Myself, I think something would still need to be pulling the surface of a finite sized sphere outwards to overcome gravitational collapse. I suspect I have no hope of seeing this for myself because I have not covered GR at all yet.
  • #32
Well, spherically-symmetric inhomogeneous universes are one of the few solutions you can do analytically. It may be a bit of a challenge to actually do, but it should be doable on paper.
  • #33
Mass, distance... that's all, right?
  • #34
For Newtonian gravity, this is the case. General Relativity, on the other hand, also depends upon velocity, pressure, and shear.
  • #35
Antiphon said:
The reason the early universe wasn't a black hole and didn't become one was because of the distribution of matter/energy/pressure. It was uniform throughout all of space and therefore there was no concentration to create an interior event horizon. It's very much like the way there is no gravity at the center of the earth.
Aha! This post helped me understand the problem. Especially the sentence, "It's very much like the way there is no gravity at the center of the earth."
*If* the concentration of mass/energy at the big bang were sitting in space surrounding it, *then* it would not spread out. Nothing could achieve escape velocity, like with a black hole. But there was no space around it. There was nothing to move into. The gravitational pull of any particle A on a particle B was balanced by another particle C on the other side of B. It was as though every particle was at the center because there was no center like being at the center of the earth. (And there still is no center to the universe.)
Of course, this leads to the question of how can the universe be like the surface of an expanding balloon if there is nothing outside the balloon? I hope this is answered somewhere.
  • #36
Okay. I thought this had been resolved by the fact that all space was wrapped up with all the matter/energy at the beginning of the universe, so that it could not be like a black hole sitting in space because there was no space outside to sit in. All particles had equal gravity acting on them from all directions.
Now, in another thread people are saying the universe in probably infinite. Either this thread is wrong or that one is. Which is it?
Let's make some progress here.
https://www.physicsforums.com/showthread.php?p=3173067
  • #37
I would condense some of the arguments to the following:
-- The Schwarzschild solution is a vacuum solution to the field equations (stress energy tensor = 0).
-- The Friedmann solution is not a vacuum solution but has stress energy tensor = diag [Density, Pressure, Pressure, Pressure]
  • #38
I believe you are seriously mistaken, Cosmic.
Show us where you saw people in that thread say that the U is "probably infinite."
I know I posted in that thread and explicitly allowed for both possibilities without saying probably one or the other. I would strongly object to being misinterpreted in such a gross fashion. Better be specific about who you mean by "people". Others might feel the same way about their statements being misrepresented.
  • #39
Look. Nicksauce has already given a concise accurate response to the question.
  • #40
Adrian.
Naturally this is conjecture but sensibly speaking if there was a big bang then it must have been the result of a singularity disruption - an event for which, under presently accepted theory, there is no cause.
There has been much debate about weather or not light excerts gravity. We all know it is influenced by gravity but does it actually exert it and if so how? Certainly if a photon's gravitational field expanded out from the photon in a gravitational wave, this could not move ahead of the photon. I can't get to grips with the maths for how it might influence another parallel photon but even rudimentry attempts seem to suggest that it's field would be diminished.
A sigularity disruption would be possible then, if there came a point when matter's collapse to ever smaller parts could only continue by being converted to pure energy.
So we have white dwarf -> neutron star -> quark star? -> WIMP star? -> photons ??
  • #41
Trenton said:
Naturally this is conjecture but sensibly speaking if there was a big bang then it must have been the result of a singularity disruption ...
It sounds like you are thinking about what in Quantum Cosmology is called the "Big Bounce".
You are considering stages of collapse and conjecturing about something that might happen at high density that turns the collapse around and starts expansion.
This as recently become a hot area of research, a recent survey paper by one of the experts is "The Big Bang and the Quantum"
http://arxiv.org/abs/1005.5491
It is getting researcher's attention for two main reasons:
A) Quantizing the main cosmology equation in a fairly simple natural way introduces quantum corrections that take effect only at very high density and make gravity effectivey repel instead of attract, thus causing a bounce
B) Observational testing experts have begun to see how the big bounce theory can be tested using Cosmic Background Radiation data (a CBR sky map that includes polarization as well as temperature fluctuations).
C) The bounce makes a satisfactory episode of cosmic inflation easier to happen without parameters being finely adjusted. It makes the universe we actually see more likely than many alternatives that might otherwise have occurred.
A recent paper on that is
http://arxiv.org/abs/1103.2475
What you are describing as a collapse followed by "singularity disruption" sounds to me like the collapse rebound caused by quantum effects at high density which the QC people call "bounce".
In any case the universe at the start of expansion forming is out of the question.
Nicksauce already explained that.
https://www.physicsforums.com/showthread.php?p=3174272#post3174272
Hopefully everybody got the message.
What I see you doing, Trenton, is going on beyond that to ask "what could have caused the start of expansion? What preceded it?" That is a good question. Definitely!
  • #42
Hmm, given the hypothetical binding energies implied by preon models, are you saying:
neutron star -> quark star -> preon star -> [unzip binding energy] -> [gamma ray burst?]​
Cool. Been trying to solve that grb riddle for a while.
  • #43
I am very baffled by quantum mechanics and although I have heard of corrections that make gravity effectivey repel instead of attract, I can't pretend to understand it! I arrived at my suspicions through a much simpler thought process. My starting position is that all boson and fermions are orbitals (wave particle duality). Certain values (of mass/energy) form stable particles, other values form unstable particles. The particles may exist in certain states (eg electrons in different energy states) but apart from that, every value in-between must be a photon. This pretty much sums up my scant knowledge and perhaps distorted interpretation of quantum theory.
So quanta of certain values will under certain conditions form particles or self-circling orbitals. Everything else can't self-circle and so flys off at a tangent (becomes a photon). In both cases the electric and magnetic fields are propagating at c in their frame of reference. Inertia can then be thought of as the resistance of circular orbitals to having their frame of reference changed. Gravity is connected to this in some way but I can't for the life of me, figure out how! I feel though, that negative gravity is a non starter. If it were to exist there would have to be such thing as negative inertia. For something to resist having it's frame of reference conserved has weird implications. Ultimately it would move infinitely fast or infinitely slow. I suspect the equation solutions that predict this are invalid. Not all solutions to all equations are valid as we know.
The 'certain conditions' applying to orbitals refer to the pressence of fields. At all points equilibrium (lowest energy) is sought. In the case of collapse from a white dwarf to a neutron star, at the point this occurs, the electron and proton orbitals find it cheaper to merge with each other than continuing to self-circle in their original form. What happens when neutron orbitals become unviable in the face of pressure is all conjecture. We don't know exactly at what mass this happens and so it is quite possible that modest sized black holes are really just cloaked nuetron stars. It seems reasonable to conject that in the end, weather there are such things as quark stars or as I suggested, WIMP stars, ultimately there will come a point where there are no viable orbitals and so everything must become a photon.
The implications are quite radical. In particular the singularity that is supossed to lie at the center of a black hole can't exist as a point of absurdly small size (such as the de-broglie wavelength derived from the mass). Instead, at the point of final collapse, which will occur at a finite, non-zero size, everything becomes light.
It is this weird property of light, that it always travels at c, that gives us a clue as to what may happen next. I will withdraw ny earlier conjecture that photons may not be able to exert gravity or be less effective at doing so than matter, but will replace it with something just as controversial:- The light can move outwards, away from the center of gravity, much further than matter could because it sheds it's mass equvilence without compromising speed. It starts out with energies in the far gamma (inflation?), slows to the gamma and starts making particle/anti-particle pairs (end of inflation?). The light that did not make particles can just kept on getting redder the further out it gets. And unless there is some law I have never heard of, even at one billionth of a hertz, it will still be traveling at c. This is how I prefer to comprehend Hawkins radiation - that actually light does escape from black holes, albeit red-shifted by a factor with a large number of noughts on the end (to 2.7K maybe?)
I do tacitly accept that the redening would require gravity which implies maybe photons can exert!
In my view the concept of curvature of space-time has been taken too far. Yes I am completely happy with the concept but not to the point where the curvature becomes infinite - the only way light could be prevented from escaping. I note though that curvature would be infinite if the singularity was of zero size but I don't see how it can get to be zero. Moreover if curvature was infinite nothing including the singularity's own gravity could escape (unless gravity travels faster than light which seems doubtful). There are further problems with the accepted notions of black holes. Rs is calculated as the radius at which the escape velocity reaches c - except that there are no Lorentz contration terms in the equation for Rs? Do they cancel out or were they omitted by mistake? Time does not stop either at Rs since the gravitational potential realized by moving from infinity to Rs is not infinite. So observers probably won't see objects freeze at the event horizon unless they are using a webcam with a Windows PC.
  • #44
FAQ: Does light produce gravitational fields?
The short answer is yes. General relativity predicts this, and experiments confirm it, albeit in a somewhat more indirect manner than one could have hoped for.
Theory first. GR says that gravitational fields are described by curvature of spacetime, and that this curvature is caused by the stress-energy tensor. The stress-energy tensor is a 4x4 matrix whose 16 entries measure the density of mass-energy, the pressure, the flux of mass-energy, and the shear stress. In any frame of reference, an electromagnetic field has a nonvanishing mass-energy density and pressure, so it is predicted to act as a source of gravitational fields.
There are some common sources of confusion about this. (1) Light has a vanishing rest mass, so it might seem that it would not create gravitational fields. But the stress-energy tensor has a component that measures mass-energy density, not mass density. (2) One can come up with all kinds of goofy results by taking E=mc^2 and saying that a light wave with energy E should make the same gravitational field as a lump of mass E/c^2. Although this kind of approach sometimes suffices to produce order-of-magnitude estimates, it will not give correct results in general, because the source of gravitational fields in GR is not a scalar mass-energy density, it's the whole stress-energy tensor.
Experimentally, there are a couple of different ways that I know of in which this has been tested. An order of magnitude estimate based on E=mc^2 tells us that the gravitational fields made by an electromagnetic field is going to be extremely weak unless the EM field is extremely intense.
One place to look for extremely intense EM fields is inside atomic nuclei. Nuclei get a small but nonnegligible fraction of their rest mass from the static electric fields of the protons. According to GR, the pressure and energy density of these E fields should act as a source of gravitational fields. If it didn't, then nuclei with different atomic numbers and atomic masses would not all create gravitational fields in proportion to their rest masses, and this would cause violations of Newton's third law by gravitational forces. Experiments involving Cavendish balances[Kreuzer 1968] and lunar laser ranging[Bartlett 1986] find no such violations, establishing that static electric fields do act as sources of gravitational fields, and that the strength of these fields is as predicted by GR, to extremely high precision. The interpretation of these experiments as a test of GR is discussed in [Will 1976] and in section 3.7.3 of [Will 2006]; in terms of the PPN formalism, if E fields did not act as gravitational sources as predicted by GR, we would have nonzero values of the PPN zeta parameters, which measure nonconservation of momentum.
Another place to look for extremely intense EM fields is in the early universe. Simple scaling arguments show that as the universe expands, nonrelativistic matter becomes a more and more important source of gravitational fields compared to highly relativistic sources such as the cosmic microwave background. Early enough in time, light should therefore have been the dominant source of gravity. Calculations of nuclear reactions in the early, radiation-dominated universe predict certain abundances of hydrogen, helium, and deuterium. In particular, the relative abundance of helium and deuterium is a sensitive test of the relationships among a, a', and a'', where a is the scale-factor of the universe. The observed abundances confirm these relationships to a precision of about 5 percent.[Steigman 2007]
Kreuzer, Phys. Rev. 169 (1968) 1007
Bartlett and van Buren, Phys. Rev. Lett. 57 (1986) 21
Will, "Active mass in relativistic gravity - Theoretical interpretation of the Kreuzer experiment," Ap. J. 204 (1976) 234, available online at http://articles.adsabs.harvard.edu//full/1976ApJ...204..224W/0000224.000.html
Will, "The Confrontation between General Relativity and Experiment," http://relativity.livingreviews.org/Articles/lrr-2006-3/ , 2006
Steigman, Ann. Rev. Nucl. Part. Sci. 57 (2007) 463
