How Do Antiparallel Currents in Two Wires Affect the Magnetic Field at a Point?
This discussion revolves around calculating the magnetic field generated by two wires carrying antiparallel currents. The original poster describes a scenario where one wire has current flowing out of the page and the other into the page, with a specific distance between them. The goal is to find the net magnetic field at a designated point, expressed in terms of current and distance.
  • Participants discuss the application of the right-hand rule to determine the direction of the magnetic fields produced by each wire. There is confusion regarding how to combine these fields as vectors rather than scalars. Some participants attempt to express distances and angles in terms of the given variables.
The discussion is ongoing, with participants providing hints and guidance on how to approach the problem. There is an exploration of how to express angles in terms of the distance between the wires and the point of interest. Multiple interpretations of the problem setup are being considered, and participants are actively seeking clarification on specific calculations.
Some participants mention constraints related to homework requirements, such as expressing angles in radians. There is also a focus on ensuring that the calculations adhere to the problem's parameters, including the need to express certain trigonometric functions in terms of the distance.
xinlan
In this problem, you will be asked to calculate the magnetic field due to a set of two wires with antiparallel currents as shown in the diagram . Each of the wires carries a current of magnitude . The current in wire 1 is directed out of the page and that in wire 2 is directed into the page. The distance between the wires is . The x-axis is perpendicular to the line connecting the wires and is equidistant from the wires.
Find the magnitude of the net magnetic field created at point L by both wires.
Express your answer in terms of I,d, and appropriate constants.
Bwire = uoI/2pid
I got the B1L created by wire 1 by point 1 only.
so I thought since they have the same current and distance, they will have the same magnitude, so I just add them. But I got it wrong.
one of the hint says "find the direction of B"
I am confused how to find the direction for wire 1 and 2 at point L.
please someone help me..
Thank you so much..
The magnetic field surrounding a current-carrying wire is tangent to a circle centered on that wire. Use the right-hand rule to find which way it points. For the current coming out of the page, point your thumb in the direction of current (out) and your fingers curl in the direction of the field (counter clockwise).
I had used the right hand rule for both currents. the other current will be clockwise right?
but I still don't understand how come it will be relevant to the question. since the hand rule only gives either counterclockwise or clockwise.
Right.
Use that rule to find the direction of magnetic field from each wire. Note that the magnetic field is a vector quantity, so you need to add them like vectors. (You can't just add them like numbers.)
For example: To find the field from wire 1 at location L, draw a line from the wire to L. The field will be perpendicular to that line with magnitude given by the formula, in a counterclockwise direction. (You'll have to figure out the distance between 1 and L, of course.) Draw the vector on the diagram.
Then do the same thing for the field from wire 2. Draw its magnetic field vector at point L.
Then add these vectors to find the net field at point L. (Find their components and add them.)
2*((uo*I)/(2pi*sr of d^2+(d*sr of 2)^2)*cos55
where sr = square root
B1x = + B1 cos 55
B2x = + B2 cos 55
so bx = B1x+B2x = 2*(B*cos 55)
where B = ((uo*I)/(2pi*sr of d^2+(d*sr of 2)^2)
then, net B = sr of Bx^2
= sr of ((2(B*cos 55))^2)
= 2(B*cos 55)
= 2*((uo*I)/(2pi*sr of d^2+(d*sr of 2)^2)*cos55
What's the distance (in terms of d) between wire 1 and point L?
this is the answer that how I put in:
Simplify that expression for the distance. I think the system is too stupid to understand.
this is the answer how I type in:
but I still got wrong
Get rid of the angle. Express the cos(55) in terms of d only.
Doc Al, thank you so much for your help..
I really appreciate it..
But i didnt get it>...<
Similar Problem
Find the magnitude of the net magnetic field B_M created at point M by both wires.
B_m=2(u_oI)/(2pi*sqrt of d^2+(2d)^2)cos(63.4) but I rewrote cos(63.4) in terms of d, (0.5) but my answer is off by a multiplicative factor.
Could you help me?
Doc, would you be so kind as to explain how we can rewrite cos(55) in terms of d. I am not quite sure how to do this.
Thanks.
Consider the right triangle 1-K-L. All sides can be expressed in terms of d. The 55 degrees corresponds to the angle at point 1; write cos(55) in terms of the ratio of the sides. (The answer will not have a d in it, of course, since they cancel.)
hint remember cos(theta) is = x/r ...in this case x is d! and r is length of b!
Sorry to bump a old thread but I just had this question in mastering physics. and it Said it MUST BE in radians.. so the 55 would have to be 0.9547. and that's all that needed to be changed to make it correct
