How Can We Observe Black Holes Growing?
  • Context: High School
  • Thread starter Thread starter mef
    Black holes Holes
The discussion revolves around the observation of black holes and their growth, particularly focusing on the dynamics of matter falling into black holes and the perspectives of different observers. It touches on theoretical aspects of general relativity, the behavior of particles with varying angular momentum, and the implications of Schwarzschild coordinates.
  • Some participants assert that from a distant observer's perspective, it appears that matter takes an infinite amount of time to fall into a black hole, raising questions about how black holes can absorb matter.
  • Others argue that matter can fall into a black hole if it loses angular momentum, typically through processes in an accretion disk.
  • One participant claims that particles with zero angular momentum fall into the black hole in finite time according to their own clocks, challenging the notion that they take infinite time from a distant perspective.
  • There is a discussion about the misconceptions surrounding the role of distant observers and the nature of events in curved spacetime, with some participants emphasizing that just because an event is not observed does not mean it does not occur.
  • Participants discuss the concept of "when" in the context of crossing the event horizon, noting that there is no unique time that can be universally applied across different reference frames.
  • Some participants express frustration over perceived misunderstandings and emphasize the importance of clarity in discussing these concepts.
There is no consensus in the discussion, as multiple competing views remain regarding the nature of black hole absorption, the role of observers, and the implications of general relativity on time and events.
Participants highlight limitations in understanding due to the complexities of general relativity, particularly regarding the definitions of time and the behavior of objects in curved spacetime. There are unresolved mathematical steps and assumptions that influence the discussion.
mef
TL;DR
A very simple question
IT IS WIDELY KNOWN that from the point of view of a distant, BUT FROM a FINITE distance, the time of falling into a black hole is INFINITE.
Then how does the BH absorb the surrounding matter?
It turns out that for any observer located at a finite distance R (the coordinate of the Schwarzschild metric) from the BH, no matter will ever reach the BH and it will never be able to absorb anything and increase in size.
mef said:
Summary:: A very simple question
Please don’t RANDOMLY SHOUT at us. It is rude and distracting
In order to fall in, matter must lose its angular momentum. Typically this happens in an accretion disk, where there are lots of collisions that can redistribute angular momentum and energy so as to allow particles to fall in.
It turns out that physics is about more than the Schwarzschild coordinates.
You are answering a completely different question.
What happens to particles with zero angular momentum (radial)?
They fall in. They reach the horizon in a finite time by their own clock (and hit the singularity a finite time by their own clock after that).
Your misconception is a common one. I suggest reading this series of Insights articles:
https://www.physicsforums.com/insights/schwarzschild-geometry-part-1/
Do you not understand what I wrote about the view, from the point of view of an outsider?
We understand what you are asking, truly we do!
The “point of view of an outsider” is based on light from the infalling object reaching their eyes. As the object approaches the horizon it takes longer and longer for that light to reach the outsider and light from the horizon crossing never gets out at all; that’s what it means to say that the object gets closer to the horizon but never crosses it.
However, if we start with an object of mass ##m## and drop it into a black hole of mass ##M##, we find that very quickly we have a black hole of mass ##M+m## - it’s just that we don’t get to see the object crossing the horizon.
Be aware that this answer contains some serious oversimplifications; the links posted by @PeterDonis would be a good start if you want a better understanding. There are also many older threads here as your question is a common one; the list of “Related Threads” below may be helpful, as well as https://www.physicsforums.com/threa...ching-a-bh-and-bh-growth.921644/#post-5814635
There are a lot of misconceptions online about an object falling into a black hole. These sources generally over-emphasise the role of a distant observer and what they see in terms of the light signals that reach them.
The argument they present, which you are repeating, is essentially that the object takes "infinite time" to reach the event horizon. This is false. There are other misconceptions, such as that the infalling object sees the whole history of the outside universe. That is also false.
One key point is that in the curved spacetime of a black hole, not all events may be observed by all observers. That the distant observer never observes an event does not mean that the event does not take place.
Please understand that the gap of knowledge here is a big one. You are dealing with people who are very well versed in relativity and also very used to seeing precisely the type of misconceptions that you present. Instead of being dismissive and ungrateful to their replies because they do not fit with your own preconceptions, you should try to understand them.
In addition to general words, no calculations.
OK.
Let's do it differently.
How much will the remote observer's clock show when, according to the local clock, matter reaches the horizon?
I'm setting a very simple task... so that it becomes completely clear to you. How long does it take for a Newtonian apple to move from Earth to a black hole in the center of our galaxy.
From Newton's point of view
OK.
You have another misconception here: The idea that a global ”when”. The idea that there is a unique time of crossing the horizon as seen by a distant observer is a false one.
Newtonian gravity does not apply to black hole event horizons. As far as the apple is concerned, it reaches the event horizon in a finite time.
mef said:
Let's write down the SPECIFIC time of the apple's fall from the Earth to the horizon of the black hole in the center of our galaxy. Take some mass of this BH. The attraction of the Earth and other gravity in the galaxy should be ignored.
By the “specific time” do you mean the proper time along the the infalling object’s worldline - that is, the time measured on the infaller’s clock between when it is released and it reaches the horizon?
If you mean something else, you will have to be more precise about exactly what the end points of the interval we’re measuring are. That’s what @Orodruin is getting at when he reminds you that there is no global “when” in curved spacetime.
Depends on how the remote observer defines "when". You are thinking three dimensionally, where you have little choice about what "when" means. In four dimensions, you have a choice. You can pick "when" so that the matter never crosses the horizon, or "when" so that it crosses almost as soon as it is released. It's a choice - not of physics, but of what you mean by the word "when". There's no universal meaning to it.
I didn't talk about Newtonian gravity, only about his apple))
there are strict initial conditions , but there is no definite answer? And then why do we need such a theory?)) How will you test students on the exam? He will write ANY answer... and he will ...this can also be))
maybe you have in terms of quantum mechanics? with such a probability, such an answer, with another probability, another answer))
  • Sad
  • Skeptical
No there aren't. You keep failing to define "when". If you do that, there is an answer.
t=0 start))
The GR calculations are in the thread I gave a link to.
mef said:
t=0 start))
You mean the Schwarzschild t coordinate? That isn't defined on the horizon so your question has no answer in those terms.
mef said:
t=0 start))
There is no "universal time in GR". Again, what you are syaing is: IF we assume universal time, then a black hole makes no sense. Which is true. Universal time (the same ##t## for everything) is not part of the theory of relativity.
No. You persist in applying your own misconceptions without any regards to being told that your question as posed is not well defined according to the theory. Obviously such a question would not be asked in an exam precisely because it is not a good question to ask.
Let me guess - you didn't come here to learn, did you? You came here to force upon us all of your misconceptions just to tell us that GR is not correct.
  • Haha
They fall in, just like particles with zero angular momentum about any spherical mass.
Why should the particle care about the point of view of an outsider?
This is not a physical question, it is a mathematical question. And even as a mathematical question it is not fully specified since you have not indicated which coordinates you want to use to determine “when” things happen. If you use mathematically bad coordinates you will get a bad mathematical answer.
It is not a simple task because it is incompletely specified. You need to specify the coordinates. And even once you do so, this remains a mathematical exercise rather than a physical one
That is correct. You cannot have a definite answer to an indefinite question
This is defined at a finite point R (observer coordinate)
On the horizon, time is defined at least as a limit, just like in mathematical analysis. At the same time, some limits may diverge to infinity, but they exist!
but there are limits that do not exist, for example, sin(1/x) for x -> 0
What makes you think I'm asking about the global when?
I'm asking about when only with the observer system
Because he's taught relativity to hundreds of students and can see the mistakes you're making.
The only question for you is whether you have the desire to learn GR, which is hard work. Or, whether you prefer not to learn it, which is very easy to do.
You quoted some Real Analysis. 99.9% of the world's population do not understand real analysis and why ##\sin \frac 1 x## does not converge, as ##x \rightarrow 0##. Real analysis is not easy to learn and many people think it's just some rubbish that mathematicians invented. It's easy for them to trash mathematics rather than learn it.
Ultimately, we've all put in the months of hard study to learn GR - and overcome the difficulties in understanding thinks like coordinate-dependence and invariance.
We can't force you to learn GR. But, you can't persuade us it's all wrong any more than you could persuade us that mathematics is all wrong. Because we've learned and understood it.
Because you are trying to construct a ”when” including both a stationary observer and an object falling through the event horizon by asking ”when” for a distant observer does an object pass the horizon. There is no such construction. The time coordinate t is just a coordinate. It does not define a universal sense of simultaneity. That no such concept exists should be clear already from special relativity. You yourself is the one standing in your own way by asserting that your ill defined questions are well defined.
No, it is not and repeating the statement is not going to make it so. Time is undefined on the horizon because regular Schwarzschild coordinates are singular there. This also underlines that coordinate time is an exceedingly bad choice to define global simultaneity. It is somewhat useful for that outside the horizon due to its role as parametrising a timelike Killing flow. This however ends on the horizon.
The hardest part of learning relativity is arguably letting go of hard ingrained preconceptions that are no longer valid.
  • · Replies 43 ·
  • · Replies 31 ·
  • · Replies 67 ·
  • · Replies 51 ·
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 40 ·
  • · Replies 22 ·
