How do change in magnetic flux induces emf in a coil ?
A change in magnetic flux through a coil induces an electromotive force (emf) according to Faraday's laws. While it is commonly believed that an electric field is necessary for electron conduction, it is clarified that electrons can move in a magnetic field without an electric field, as seen in circular motion. The curl of the electric field is related to the time rate of change of the magnetic field, as described by Maxwell's equations. Therefore, a changing magnetic field induces an electric field that facilitates electron movement in the coil. This interaction is fundamental to understanding electromagnetic induction.
hanii
According to Faraday's laws... change in magnetic flux linking a coil induces current in the coil.., but for conduction of electrons ...there must be an electric field ! how is the electric field induced in the coil??
welcome to pf!
hi hanii! welcome to pf! :wink:
hanii said:
… for conduction of electrons ...there must be an electric field !
not true …
for example, an electron moving in and perpendicular to a purely magnetic field will move in a circle at constant speed …
(and if it moved through an electric field, it would do work and either lose or gain energy, but here it doesn't)
The curl of the electric field is equal to the negative of the change in the magnetic field with respect to time. Take a look at Maxwell's equations. So, when there is a changing magnetic field (which we have in this case), an electric field is induced which drives the electrons around the coil.
  • · Replies 193 ·
21K
  • · Replies 16 ·
  • · Replies 27 ·
