How do I calculate the ratio of forces between two conducting spheres?
The discussion revolves around calculating the ratio of forces between two conducting spheres, particularly after they come into contact and share charge. The subject area involves electrostatics and Coulomb's law.
  • Participants explore the implications of charge distribution after the spheres touch and question how this affects the forces between them. There is a focus on the assumptions regarding the equality of forces and the conditions under which they might differ.
Some participants have provided guidance on the charge distribution after contact, noting that the total charge is split equally between the spheres. However, there is still exploration regarding the forces before and after the spheres touch, and no consensus has been reached on the final calculations or interpretations.
There is an emphasis on the initial conditions of the spheres and the nature of the charges involved, with some participants questioning the assumptions made about the forces being equal.
samcoelho
Two identical conducting spheres are charged to +2Q and -Q, respectively, and are separated by a distance d (much greater than the radii of the spheres) as shown above. The magnitude of the force of attraction on the left sphere is F1. After the two spheres are made to touch and then are reseparated by distance d, the magnitude of the force on the left sphere is F2. Which of the following relationships is correct?
Coulomb's Law: F=k|q1q2|/r^2
Here are the answer choices:
a) F1 = 2F2
b) F1 = 8F2
c) 2F1 = F2
d) F1 = 4F2
e) F1 = F2
I figured that Coulomb's law would tell us the magnitude of the forces are identical, so I answered E, but that was incorrect.
(Screenshot of question attached)
After the spheres touch, how much charge is on each?
If the magnitude of the forces was unequal, we could use this experiment to propel a space vehicle.
You seem to have misread the question.
Equal amount, so does each sphere then have 1/2 Q charge?
Yes, well done.
The total charge is (2Q) + (-Q) = Q. Since the spheres are identical, this total charge gets split equally, ##\frac Q 2## each.
Steve4Physics said:
Yes, well done.
Good.
Now finish off. What are the before & after forces?
9K
