How do I calculate this Poisson bracket in QED?
1 reply · 2K views
0celo7
To calculate a certain Dirac bracket I need to calculate this Poisson bracket (Weinberg QTF 1 p.349 first eq.)
$$[F,\Pi_i(\mathbf{z})]_P$$
where F is any functional of matter fields and their conjugates and pi is the conjugate to the vector potential. It should be zero.
The Poisson bracket for two functionals is defined as
$$[U,V]_P=\int d^3x\left[\frac{\delta U}{\delta A^i(\mathbf{x})}\frac{\delta V}{\delta \Pi_i(\mathbf{x})}-\frac{\delta V}{\delta A^i(\mathbf{x})}\frac{\delta U}{\delta \Pi_i(\mathbf{x})}\right]$$
$$\boldsymbol{\Pi}=\dot{\mathbf{A}}+\nabla A^0$$
$$\nabla\cdot\mathbf{A}=0$$
$$\nabla\cdot\boldsymbol{\Pi}=-J^0=\nabla^2 A^0$$
I tried plugging things into the definition of the Poisson bracket:
$$[F,\Pi_i(\mathbf{z})]_P=\int d^3x\left[\frac{\delta F}{\delta A^j(\mathbf{x})}\frac{\delta \Pi_i(\mathbf{z})}{\delta \Pi_j(\mathbf{x})}-\frac{\delta \Pi_i(\mathbf{z})}{\delta A^j(\mathbf{x})}\frac{\delta F}{\delta \Pi_j(\mathbf{x})}\right]=\int d^3x\left[\frac{\delta F}{\delta A^j(\mathbf{x})}\delta_{ij}\delta^3(\mathbf{x}-\mathbf{z})-\text{something}\right]$$
I'm not sure what the something is, but it has to be δF/δA(x) for the PB to vanish. Since these are variational derivatives and not straight partials, I reasoned that from the above definition of ∏, a variation of A causes a variation in ∏ like
$$\delta \Pi^i(\mathbf{z})=\frac{\partial}{\partial t}\delta A^i(\mathbf{z})$$
so the variational derivative is
$$\frac{\delta \Pi_i(\mathbf{z})}{\delta A^j(\mathbf{x})}=\delta_{ij}\frac{\partial}{\partial t}\delta^3(\mathbf{z}-\mathbf{x})$$
This is zero and not at all what I'm looking for. Integration by parts does not help here either.
So I was thinking chain rule. Say I have the variational derivative δF/δA(x) and I expand in terms of ∏ derivatives:
$$\frac{\delta F}{\delta A^i}=\frac{\delta \Pi_j}{\delta A^i}\frac{\delta F}{\delta \Pi_j}$$
Of course the sum goes over the ∏s. But in the OP i calculated the variational derivative of ∏ w.r.t. A:
$$\frac{\delta\Pi_j(\mathbf{x})}{\delta A^i(\mathbf{z})}=\delta_{ji}\frac{\partial}{\partial t}\delta^3(\mathbf{x}-\mathbf{z})$$
But the delta tensor and function are symmetric w.r.t. index and argument permutation, so the following equality holds (maybe):
$$\frac{\delta\Pi_j(\mathbf{x})}{\delta A^i(\mathbf{z})}=\frac{\delta \Pi^i(\mathbf{z})}{\delta A^j(\mathbf{x})}$$
I think this is right.
