Planobilly
- 116
Hi,
My last amp design/build has failed to operate as planned. There are several perplexing issues I do not know the cause of. I started the amp up and it will play and has all the voltages I expected within a few volts.
Issues
1. Serious amount of 60hz hum.
2. Channel two gain and volume control interacting in a very non standard way.
3. Every component in the preamp stage is microphonic. I have never seen a amp do that. What I mean by that is when I tap on a component I hear the tap sound in the speaker.
What I had in mind with the design..
I am trying to combine a channel from an old Fender Bassman with a channel from a modern high gain Fender EVH 5150. The amp is class AB push pull 100 watt.
As I have invested a large amount of time, effort, and money in this amp, I am not very happy with the prospects of accepting failure as the outcome.
I assume I can find and fix the hum issue. Perhaps that will not be easy but...
I assume I can fix the gain/volume control issue...
I have absolutely no idea what could cause a seven stage preamp section to display a microphonic condition. Obviously there is not enough information in this post for anyone to comment as to the exact causes of the above faults. I can post all the schematics and give a detailed assessment of the faults with oscope screen shots where needed.
My question at the moment is where do I start? I assume I should try to fix the hum issue first.
Is that the best place to start?
Thanks,
Billy
Issues
Thanks,
Billy
