How do I determine torque required to accelerate
  • Thread starter Thread starter Gizmo72
    Accelerate Torque
8 replies · 7K views · last reply
Gizmo72
Referring to the attached diagram, how do I determine the torque required to uniformly accelerate the object about the vertical axis XX from rest to 50 rpm in 5 seconds?
  • Side-view engineering drawing of a composite body along a horizontal axis: a cone on the left (diameter 180, length 350, 22kg), a cylinder of diameter 100 and length 500 (30kg), and a hemisphere on the right labelled SR 100 (16kg), with a vertical section line XX at 200 from the cone base.
First step: Determine equation relating torque and angular acceleration.
What I have so far is
w = 50rpm = (50x2pi)/60 = 5.23 rad/s
w = wo+at
a=(5.23-0)/5 = 1.046rad/s^2
T=mr^2a
T=68x.05x1.046 0.17782Nm
But now I'm thinking I need to be using T=Iga (Moment of Inertia x acceleration) but I can't work out how to calculate the moment of inertia...i've only ever done that for a uniformly shaped object e.g. a cylinder.
Don't know, I may be just confusing myself as usual
Well, do you know how to calculate the I for an object which is made up of several smaller objects?
No, that's where I'm stuck...I am on the right track though with my assuming I need the moment of inertia?
I could guess that I calculate the "I" for each of the smaller objects then take the average?
you can calculate the second moment of area for each shape then
moment of inertia = mass per unit area x second moment of area
second moment of area for a triangle is bh^3 / 36
for a rectangle is bd^3 / 12
for a semis circle its 0.1102 R^4
then all you need to do is use the moment of inertia in the formula torque = moment of inertia x angular acceleration
You'll need to calculate the mass moment of inertia of the different shapes and combine them. FYI, the mass moment of inertia is generally not equal to mass per unit area x second moment of area. You are dealing with 3-dimensional bodies.
This Table gives the moment of inertis for various shapes about various orthogonal axii:
http://www.engr.colostate.edu/~dga/mech324/Labs/Lab%2010/images/moment%20of%20inertia%20table.jpg
Use the Parallel Axis Theorem to get specific moments of inertia for each shape.
Bob S
