Determining Y without X: Solutions Explained
  • Thread starter Thread starter ThanaH
Determining the value of Y without knowing X is impossible in the equations y=x - 22081 and y=x - 28398, as Y is dependent on the changing value of X. Since Y is defined by the equations, it cannot be isolated as a constant without a specific value for X. The discussion concludes that without knowing X, Y cannot be accurately calculated. Therefore, the answer to the question is no, Y cannot be determined without X.
ThanaH
I need to determine the answer for Y in the following question:
y=x - 22081 and y=x - 28398. X is a changing factor as the amount deducted changes every time. But Y is a constant amount - never changes. Is there a way to determine y without knowing x?
Thank you.
Mathematics news on Phys.org
No, there isn't.
Thank You !
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
