How do i identify an unknown gas knowing very little
  • Thread starter Thread starter charizzardd
    Gas
The discussion focuses on identifying an unknown gas contained in a syringe using pressure transducers and LabVIEW software to graph voltage changes. The user is exploring relationships between molar mass, voltage, and the ideal gas law, while considering thermodynamic equations and energy calculations. Key methods include using the ideal gas equation, Boyle's law, and Maxwell relations to derive pressure and volume relationships. The user seeks guidance on how to leverage these principles to identify the gas based on the measured voltage and volume.
  • Understanding of the ideal gas law and its applications
  • Familiarity with thermodynamic equations and Maxwell relations
  • Knowledge of pressure transducers and their operation
  • Experience with LabVIEW software for data acquisition and analysis
  • Research the relationship between molar mass and voltage in gas sensors
  • Learn how to implement the ideal gas equation in LabVIEW for real-time data analysis
  • Explore methods for calculating the number of moles and molecular weight from pressure and volume data
  • Investigate different types of gas sensors and their voltage outputs
Students and researchers in chemistry and engineering fields, particularly those involved in gas analysis, thermodynamics, and instrumentation using LabVIEW.
charizzardd
b]1. Homework Statement [/b]
I have to design a procedure to figure out what an unknown gas inside a syringe of known volume is. We are also given pressure transducers and have software(labview) that will allow us to graph voltage created by changing the volume of the syringe. I have no clue how to do this.
Is there some relationship between molar mass, and voltage? I have been messing around with ideal gas equation, boyles law, and maxwell relations but I still can't get anywhere with this.
Basically we need to design the procedure using only air, so that we can eventually do our procedure on an unknown gas sample in a syringe and identify the gas. I am not even looking for complete answers, maybe just some tips. How can I identify the gas knowing only volume and voltage created. I guess I can figure out the pressure as well using a bourdon gage or something, but that is it. Please help!
Thermodynamic equations,
p=p(V,T) where p is pressure, V is volume, and T is temperature.
(\Deltap=(\partialp/\partialV)_{T}dV + (\partialp/\partialT)_{V}dT
*note all superscripts are subscripts, i don't klnow why it is coming in as super when i put it in as sub, anyway, they are just denoting that that variabvle is constant fro that partial derivative.
or maybe energy? I am also thinking that if i can graph the voltage, then perhaps I can find the current associated with that, Power=VI, which is in watts/s from here I can equate work and power, work being the change in internal energy as there is no temperature change. Well I am sure there is, but it is negligable and therefore not counted. The fluid is being treated as an ideal gas, at constant pressure and mass.maxwell equations
U=U(s,V):
\DeltaU=(\partialU/\partials)_{V}dt + (\partialU/\partialV)_{s}dVThen \DeltaU=Q-W
W also = \intpdV where p is pressure and V is volume.
Perhaps I can find mass from here, and using ideal gas finding the numbe rof moles, and using it to find the molecular weight, and there for identifying the gas.
Hope someone can point me in the right direction!
The voltage must refer to a sensor of some kind. Your question can't be answered without knowing the type of sensor.
  • · Replies 109 ·
  • · Replies 35 ·
