How do I install babel in Texmaker
  • Thread starter Thread starter Rectifier
    install
4 replies · 3K views
Rectifier
Hey there!
How do I install babel language pack in Texmaker? I want to use
Code:
\usepackage[swedish]{babel}
in Texmaker. (Jag är bäst in Texmaker gives Jag r bst when I compile the code)
I use Win8 and the Miktex.
Your problem is not solved by using babel, which is why the output was incorrect (unless you got a specific error, babel is most probably installed on your system).
Add instead
Code:
\usepackage[utf8]{inputenc}
Add instead
Code:
I don't know what this line does but it solved my problem. Thank you.
LaTeX normally can only deal with the standard ASCII characters. To get, for instance, ä, you need to input
Code:
\"a
The package inputenc allows one to work with an extended characterset, such that characters like å, ä, ô, é, etc., are handled correctly.
Thank you!
