How do I integrate these two functions?
  • Context: Undergrad
  • Thread starter Thread starter hhkeep21
    Functions Intergration
5 replies · 3K views
hhkeep21
Hello, I'm having difficulty intergrating the following two functions:
1) (6x-x^2)^(-1/2)
I'm fairly sure that you need to intergrate by parts for this function, but I can't figure out how to do it
2) e/(e^(2x)-1)
This one I thought could do with inverse trig functions but I'm drawing a blank there also
Can someone please help me?
1) [tex]\int \frac{1}{\sqrt{6x-x^2}} dx[/tex]
Whenever I see something like that, I take out as much of the x's from the square root as possible. So let's take out an x^2 :)
[tex]\int \frac{1}{\sqrt{6x-x^2}} dx = \int \frac{1}{\sqrt{x^2}\sqrt{\frac{6}{x} -1}}[/tex]
Now that's starting to look like something a trig substitution can help :)
I seem to remember [itex]\sec^2 u -1 = \tan^2 u[/itex] :)
So to make it very convenient, the 6/x would be nice to be sec^2 u.
So let x= 6 cos^2 u. Thats a nice substitution :)
2)[tex]\int \frac{e^x}{(e^x)^2-1} dx[/tex]
u=e^x, du = e^x dx
So it becomes [tex]\int \frac{1}{u^2-1} du[/tex]
To finish that off, realize the bottom factors by difference of two squares into (u+1)(u-1) and use partial fractions.
Thank you so much for your help, I really appreciate it
A shorter version is:
[tex]\int \frac{dx}{\sqrt{6x - x ^ 2}} = \int \frac{dx}{\sqrt{- \left( -6x + x ^ 2 \right)}} = \int \frac{dx}{\sqrt{9 - \left( x ^ 2 - 6x + 9 \right)}} = \int \frac{dx}{\sqrt{9 - \left( x - 3 \right) ^ 2}} = ...[/tex]
Usually, when you encounter the form:
[tex]\int \frac{dx}{\sqrt{Ax ^ 2 + Bx + C}}[/tex]
We divide it into 2 cases:
The first case is A > 0, we'll try to arrange the integral above to the form:
[tex]\int \frac{dx}{\sqrt{Ax ^ 2 + Bx + C}} = \int \frac{dx}{(mx + n) ^ 2 + \alpha ^ 2}[/tex]
Then use the substitution:
[tex]mx + n = \alpha \tan t[/tex]
The second case is A < 0, we'll re-arrange it to:
[tex]\int \frac{dx}{\sqrt{Ax ^ 2 + Bx + C}} = \int \frac{dx}{\alpha ^ 2 - (mx + n) ^ 2}[/tex]
[tex]mx + n = \alpha sin t[/tex]
Is it clear? Can you complete the problem now? :)
Your problem is in the second case. :smile:
Well I'm having difficulty with the parts problem now because you must make the denominator equal to zero to solve for A and B to solve the equation, but e^x + 1 never equals zero so I'm a little confused how to solve it?
Gib Z said:
1)
u=e^x, du = e^x dx
[tex]\frac{1}{u^2-1}=\frac{1}{2(u-1)}-\frac{1}{2(u+1)}[/tex]
Does that help?
