How do I make a Yagi-Uda antenna smaller?
  • Thread starter Thread starter tackyattack
    Antenna
8 replies · 9K views · last reply
tackyattack
I am trying to build a Yagi antenna for 900mhz and I am using this formula:
http://www.skyscan.ca/Antennas.htm
Length:
Reflector length = 0.495 x wavelength
Dipole radiator = 0.473 x wavelength
Director D1 = 0.440 x wavelength
Director D2 = 0.435 x wavelength
Director D3 = 0.430 x wavelength
Spacing:
R-DR = 0.125 x wavelength
DR - D1 = 0.125 x wavelength
D1 - D2 = 0.250 x wavelength
D2 - D3 etc = 0.250 x wavelength
But the problem is, when I use this formula with 900mhz the antenna ends up being huge. What I need to do is make it smaller. Would it work if I took all of the lengths and spacings then divide it by, say four?
Length:
Spacing:
Nope. The size of the antenna is what makes it efficient. And since you are talking about a Yagi antenna, it sounds like you are aiming for high gain, correct?
Yes for high gain.
I found a small Yagi for 800mhz:
https://www.amazon.com/dp/B0006H4FVM/?tag=pfamazon01-20
This is a small antenna and it works. How did they get it to be small and still work?
Is is smaller than the one you calculated?
Way, way, way smaller. The reflector ended up being about 12 feet long, that is wwwaaayyyy to big.
Nah, there must be a typo in your math. A wavelength in free space at 900MHz is 1/3 of a meter, so a half wavelength is 1/6 of a meter. That is the basic size of each of your elements.
Can you show your math where you plugged in numbers into the formulas in your original post (OP)?
wavelength = 900mhz
0.495 x 900 = 445.5
there is 37.125 feet in 445.5 inches
wavelength = 900mhz
0.495 x 900 = 445.5
900MHz is the frequency, and the speed of light c is the velocity (300*10^6 m/s)
Wavelength = velocity/frequency.
So what is the wavelength at 900MHz? Should be about 1/3 of a meter.
http://en.wikipedia.org/wiki/Wavelength
Ahh I see! So at 900mhz the reflector would be 6.48956682 inches or 0.164835 meters long?
Thanks!
