How Do I Set Up the Schrodinger Equation for This Wave Function?
  • Thread starter Thread starter apigban
apigban
Hi! I am having some problems in setting up the Schrodinger equation for a particle described by the wave function:
\Psi = A sinh (x)
should I use the exponential form of the hyperbolic function?
[URL]http://62.0.5.135/upload.wikimedia.org/math/9/c/7/9c74b71126c6bb1f4d6b865019a2735e.png[/URL]
Also, for normalization, do you have any guides that show how to form the complex conjugate of the above function (i don't see the complex parts).
What's the problem with the Schroedinger equation? Are you using the time-independent version (I assume you should be), is there a potential energy associated with this wavefunction?
Further, the complex conjugate of a real valued function is just the real function again. So normalization should look something like:
1=A2 \intsinh2(x)dx
This is my solution to the normalization of the wave equation. I am sorry I am totally new at this.
[PLAIN]https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/249293_246586558696823_100000364410765_866703_7618168_n.jpg
Is it correct? I just followed wikipedia's
http://en.wikipedia.org/wiki/Normalizable_wave_function#Example_of_normalization
My question on the Schroedinger Eq. is that: Should i use the exponential form of the hyperbolic function? or does it matter if i use the hyperbolic? In the normalization above i used the exponential form.
When you use the wavefunction in the Schrodinger equation, it shouldn't matter what form (hyperbolic or exponential) you use. Your normalization is off however. The integral of sinh2(x) is:
Exponential form: \frac{1}{4} (exp(2x)/2+exp(-2x)/2-2x)
Hyperbolic form: \frac{1}{4} (sinh(2x) -2x)
Further, you need to take the integral only between o and L, the other parts can be ignored. I may be reading this wrong, but it seems like you tried to absorb the exponentials into A2 and ignored any actual integration.
Cheers,
-Malus
thanks! I did the integration. and found what the factor is. thanks also for pointing that hyperbolic or exponentials can be used!.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
