How Do S-Parameters Affect Attenuation in WG Transitions and Circulators?
  • Thread starter Thread starter lennybogzy
Attenuation measurements in a waveguide setup can vary significantly between ports, with differences of up to 1dB observed. The discussion highlights the potential influence of S-parameters, particularly S21 and S11, on these discrepancies, suggesting that transitions and circulators may be the culprits. While insertion loss is zeroed out during measurements, variations in VSWR and mismatch loss could still impact the readings. The conversation emphasizes the need to analyze S-parameters to identify which components are causing the inconsistencies. Understanding mismatch loss is crucial for correlating these attenuation measurements effectively.
lennybogzy
I was hoping someone might have some insight as to how I can correlate some attenuation measurements.
Here is my setup:
I have a KU-band CW source going into a 3-port switch, into 3 semi-rigid SMA's into 3 waveguide transitions, into 3 circulators, into 3 long pieces of waveguide. On the back end the three go into 3 more sets of circulators, transitions, SMA's and then back into a switch on which I have a power meter.
I can then switch between the three different paths and measure 3 DUT's, one at a time.
The issue that I have is that I have different attenuation measurements from port to port. Some can differ by as much as 1dB.
Here is my question:
I'm pretty sure it is the transitions and/or the circulators that are causing this port to port deviation. What should I look at in terms of the s-parameters of the transitions and/or circulators to see which ones are giving me this headache, which ones to pair together, etc. What would give me the greatest insight?
You should look at the S21. If you want to know the loss between transitions, just measure it on a network analyzer, however this could get tricky in terms of calibrating on a VNA though.
I understand the importance of looking at the loss. However, when I take my attenuation readings, I zero-out the insertion loss of each port every time. Therefore, I would expect that the loss in the transitions shouldn't affect my attenuation readings, even if they're all different because it just gets offset. My feeling is that maybe this has to do with s11. Anyone have any input as to how VSWR interactions would affect attenuation readings (after insertion loss is zeroed)?
Hypothetical example: I connect waveguide to waveguide, REL my power meter so it reads 0.00dB in each port.
Then I put in some sort of pad or coupler or whatever. 1 port reads 5.2dB one reads 4.8dB and another reads 4.43dB. What could cause this.
When you say you get 5.2 dB and another reads 4.8 dB, are you saying you have 2 identical pad/coupler/whatever? It could be just variations along between one device to another.
There is something call mismatch loss and it related to S11, ML = 10 \log_{10} (1-|\rho|^2).
Right, what I mean is if I take the same one and move it from port to port, I'll have these different readings.
I'll look into mismatch loss, thanks.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
