MHB Approximating Equations for Unknowns: How to Justify the Form of $U_0$?
  • Thread starter Thread starter evinda
The discussion centers on justifying the form of the equation for the unknown $U_0$ in a finite difference method for a boundary value problem. The initial approach using the first derivative approximation led to an incorrect equation, prompting a reevaluation that includes a second-order correction from Taylor expansion. The matrix of coefficients $A$ is analyzed for invertibility, with the conclusion that it cannot be guaranteed for all functions $q$ and step sizes $h$. However, under certain conditions, particularly with small $h$, the matrix approaches a form that is likely invertible. The error in the approximation is noted to be of order $O(h^3), suggesting that it can be considered negligible in the limit as $h$ approaches zero.
evinda
MHB
Hello! (Wave)
Given the problem $$-u''(x)+q(x)u(x)=f(x), 0 \leq x \leq 1, \\ u'(0)=u(0), \ \ u(1)=0$$ where $f,g$ are continuous functions on $[0,1]$ with $q(x) \geq q_0>0, x \in [0,1]$. Let $U_j$ be the approximations of $u(x_j)$ at the points $x_j=jh, j=0, 1, \dots , N+1$, where $(N+1)h=1$, that gives the finite difference method $$-\frac{1}{h^2}\left (U_{j-1}-2U_j+U_{j+1}\right )+q(x_j)U_j=f(x_j), \ \ 1 \leq j \leq N \\ \frac{1}{h}(U_1-U_0)-U_0=\frac{1}{2}h\left (q(x_0)U_0-f(x_0)\right )$$ where $U_{N+1}=0$.
I have to justify the form of the equation for the unknown $U_0$. We have that the approximation of the first derivative $u'(x_j)$ is $$u'(x_j) \approx \frac{u(x_{i+1})-u(x_{i-1})}{2h}$$
so from $u'(0)=u(0)$ we have $$\frac{U_1-U_0}{h}=U_0 \Rightarrow \frac{1}{h}(U_1-U_0)-U_0=0$$ but this is not the desired result.
What have I done wrong? How do we get $\frac{1}{h}(U_1-U_0)-U_0=\frac{1}{2}h\left (q(x_0)U_0-f(x_0)\right )$ ? (Thinking)
Mathematics news on Phys.org
Hey evinda! (Smile)
I believe we're including the second order correction:
$$u(h) = u(0) + hu'(0) +\frac 12 h^2 u''(0)$$
Thus
$$u(h) =u(0) + hu(0) +\frac 12 h^2\Big(q(0)u(0)-f(0)\Big) \\
\Rightarrow U_1 = U_0 + hU_0 +\frac 12h^2\Big(q(0)U_0-f(0)\Big)
(Thinking)
I like Serena said:
Hey evinda! (Smile)
Thus
(Thinking)
I see... So do we suppose that at the Taylor expansion there is no error? (Thinking)
- - - Updated - - -
Also how could we show that the matrix of coefficients
$A=\begin{bmatrix}
-\frac{1}{h^2}+\frac{1}{h}+\frac{q(x_0)}{2} & -\frac{1}{h^2} & 0 & 0 & \cdots& 0\\
-\frac{1}{h^2} & \frac{2}{h^2}+q(x_1) & -\frac{1}{h^2} & 0 & \cdots & 0 \\
0 & -\frac{1}{h^2}& \frac{2}{h^2}+q(x_2) & -\frac{1}{h^2} & & 0\\
& & & & \ddots & 0 \\
& & & & & -\frac{1}{h^2}\\
& & & & -\frac{1}{h^2} & \frac{2}{h^2}+q(x_N)
\end{bmatrix}$
is invertible? (Thinking)
There will still be an error, just an order of magnitude less.
Not bad eh? (Mmm)
$A=\begin{bmatrix}
\end{bmatrix}$
We won't be able to guarantee that it's invertible for any $h$ and any function $q$.
I think that for any $h$ there will be a function $q$ such that the matrix is not invertible.
However, we can write $A$ as:
$$A=\frac 1{h^2}\begin{bmatrix}
-1+h+h^2\frac{q(x_0)}{2} & -1 & 0 & 0 & \cdots& 0\\
-1 & 2+h^2q(x_1) & -1 & 0 & \cdots & 0 \\
0 & -1& 2+h^2q(x_2) & -1 & & 0\\
& & & & & -1\\
& & & & -1 & 2+h^2q(x_N)
\end{bmatrix}$$
And if $h$ is small enough, it approaches:
$$A \approx \frac 1{h^2}\begin{bmatrix}
-1 & -1 & 0 & 0 & \cdots& 0\\
-1 & 2 & -1 & 0 & \cdots & 0 \\
0 & -1& 2 & -1 & & 0\\
& & & & & -1\\
& & & & -1 & 2
\end{bmatrix} $$
Would that be invertible? (Wondering)
Not bad eh? (Mmm)
& & & & & -1\\
\end{bmatrix}$$
& & & & & -1\\
& & & & -1 & 2
\end{bmatrix} $$
From the wiki on tridiagonal matrices, it would appear so, since this particular matrix has all the off-diagonal elements equal (it's also Toeplitz, but that's more general). However, these results have only been obtained around 1996 or 1997 - fairly recently. Not sure they've made their way into a lot of textbooks yet.
Not bad eh? (Mmm)
We would have an error of order $O(h^3)$. Can we ignore it since it converges to $0$?
If so, how could we justify it formally? (Thinking)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
