How Do You Calculate Current from a Faraday Disc?
Calculating current from a Faraday disc involves considering factors like back electromotive force (emf) and the specific motor's torque. While voltage calculations are more straightforward, determining current requires additional complexity. Using a flat coil instead of a solid disk can enhance efficiency if the coil's magnetic field aligns with the stator magnets. Resources like the linked article provide further insights into the topic. Understanding these principles is crucial for effective generator design and performance.
charlie r
Hi,
How do you calculate the current from a faraday disc? I have found calculations for the voltage, but what about the current?
I think it is a bit more complicated due to back emf, but if you know what motor you are using (the torque it can generate), then can you work it out?
Thanks for any help,
Charlie
Thanks Drakkith, great link.
It seems that this isn't as simple as i first hoped it was!
Charlie
If you use a flat coil instead of solid disk and coil is wind in such direction, that its magnetic field adds to the field of stator magnets, the generator will be more efficient.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
