Clari said:
A coil of self-inductance 0.7H is joined in parallel with a non-inductive resistance of 50 ohm. Calculate the total current, the current through the wattless and power components when connected to a supply of 200V at a frequency of 50Hz.
Here is my steps:
Impedance Z= root [ 50^2 + (2pi*50*0.7)^2 ] = 225.5 ohm
Total current = 200/ Z = 0.9756A
Am I right? as for the other two questions, i really don't know how to solve them.
Please help me with it. Thank you!
Clari
the equation for total impedance Z you used above would apply to a
series circuit with coil inductance 0.7H and resistor resistance 50 ohms.
however, in this case, these 2 components are in parallel, and you would first need to compute Z
total using (complex impedances):
\frac{1}{Z_{total}} \ = \ \frac{1}{Z_{coil}} \, + \, \frac{1}{Z_{resistor}}
and then use:
Total \ Current \ Magnitude \ = \ \frac{200 \ Volts}{|Z_{total}|}
an easier method for this
parallel circuit is to sum the currents thru each branch of the parallel circuit:
\mbox{Current Thru Coil} \ = \ \frac{200}{2 \pi (50)(0.7)\mathbf{j}}
\left ( \ \ \mbox{Current Magnitude Thru Coil} \ = \ \left | \, \frac{200}{2 \pi (50)(0.7)\mathbf{j}} \, \right | \ = \ \frac{200}{2 \pi (50)(0.7)} \ \ \right )
\mbox{Current Thru Resistor} \ = \ \frac{200}{(50)}
\mbox{Total Current Magnitude} \ = \ \, \left \Large | \, \mbox{Current Thru Coil} \ + \ \mbox{Current Thru Resistor} \, \right |
this also answers the last 2 questions of your problem.
(*** Clarifications/corrections added from suggestions by OlderDan ***)
