How do you calculate pressure in a plasma?
  • Context: Graduate
  • Thread starter Thread starter RGClark
    Plasma Pressure
The calculation of pressure in plasma involves both kinetic pressure and electrostatic pressure due to the Coulomb repulsion of ionized molecules. In a quasi-neutral plasma, any charge imbalance leads to significant electrostatic forces, contributing to the total pressure as p + ED/2. Additionally, magnetic pressure, represented as BH/2, plays a crucial role in plasma confinement, particularly in tokamaks where external coils and internal currents create the necessary magnetic fields. Understanding these dynamics is essential for effective plasma confinement and manipulation.
  • Understanding of plasma physics and quasi-neutrality
  • Knowledge of electrostatic pressure calculations (ED/2)
  • Familiarity with magnetic confinement techniques in tokamaks
  • Basic principles of thermodynamics related to kinetic pressure
  • Research the role of electrostatic pressure in plasma dynamics
  • Study the principles of magnetic confinement in tokamaks
  • Explore the effects of temperature gradients on plasma behavior
  • Investigate the Joint European Torus (JET) and its contributions to fusion research
Researchers in plasma physics, engineers working on fusion technology, and students studying thermodynamics and electromagnetic fields will benefit from this discussion.
RGClark
A gas has some pressure due to simply its heat. However, if the some or all of the molecules are ionized it will also have some additional pressure due to the Coulomb repulsion of the molecules at the same charge.
How do you calculate the total pressure depending on the proportion of ionized molecules?
Suppose you were able to remove all the electrons from the system that were stripped from molecules that were ionized. Would the result be the same in that case?
Bob Clark
Bob,
Plasmas are usually "quasi-neutral".
This means that the unbalance between negative ans positive charges is usually very small. This is because any small unbalance lead to huge electrostatic forces.
However, with an unbalance, an electrostatic field may occur in the plasma. This gives rise to the usual electrostatic pressure ED/2. The mechanical balance equation should then include the sum of the "kinetic pressure" and the electrostatic pressure: p + ED/2. The kinetic pressure should be very high since plasma occurs at temperatures above -say- 1eV or 11000K.
As you can see, plasma cannot stay confined if there is not a force to equilibrate the pressure dur to the temperature. Forces by wall cannot be considered usually. Magnetic force are used in laboratories. The equilibrium is obtained by include the magnetic pressure term BH/2.
In plasmas, the temperature of ions and electron are often different. Then, different pressures and equilibrium have to be considered.
In tokamaks, the confinement magnetic field is obtained from a combination of extranl coils and a large current within the plasma itself. Due to the different rate of diffusion of charged species, there is also an electric field that arise, specially in edge of the plasma where tempertare and density gradients are large. This electric field combined with the magnetic configuration can cause a rotation of the plasma.
Have a look at the http://www.jet.efda.org/pages/fusion-basics.html" on the Joint European Torus web site.
Michel
  • · Replies 27 ·
  • · Replies 49 ·
  • · Replies 32 ·
10K
