How Do You Calculate Projectile Motion for a Missile Launched at an Angle?
The discussion revolves around a projectile motion problem involving a missile launched at an angle. The original poster presents a scenario where a missile is launched with a specific velocity and angle, and several questions are posed regarding its motion, including components of velocity, time of flight, altitude, and horizontal distance traveled.
  • Exploratory, Assumption checking
  • Participants discuss the initial vertical and horizontal components of velocity, the time to reach maximum height, total flight time, altitude, and horizontal distance. There is an emphasis on verifying the calculations and understanding the underlying principles of projectile motion.
Some participants have offered feedback on the original poster's calculations, indicating that the results appear to be correct. However, there is a request from the original poster to delete the thread to prevent misuse of their answers, which highlights concerns about academic integrity.
The original poster expresses uncertainty about posting in the correct area and seeks assistance while also being cautious about sharing their work with classmates. Forum rules regarding the deletion of threads after responses are noted, emphasizing the forum's role as a resource for others.
elgato11
Hi,
not sure if I am posting in the correct area but I need some help looking over a piece of homework.
The question is in the image I have linked below but I will type out the question anyway.
A missile leaves the ground with a velocity of 200ms-1 at an angle of 60° to the horizontal. Assume the acceleration due to gravity is 10ms-2.
Questions
a) The initial vertical component of the velocity
b) The initial horizontal component of the velocity
c) The Time taken to reach maximum height
d) The total time of the flight
e) The altitude obtained
f) The horizontal distance traveled during the flight.
Link to my attempt at solutions ---------------- http://tinypic.com/r/2igbn2u/6any help would be appreciated thank you.
elgato11 said:
Hi,
Questions
Your results look fine.
Thanks for the help in checking over my answers. could I ask that this thread be deleted to prevent my fellow classmates using my answers to turn in their work.
Can't do that; It's against forum rules to delete threads once they've been responded to. One purpose of the forum is to serve as a database of hints, help, strategy and methods for others to consult.
If you want to disguise the questions that you post, you can concoct similar questions from the originals and work though them on the forum to check/prove your methodology.
  • · Replies 21 ·
27K
  • · Replies 36 ·
