How Do You Calculate the Design Angle θ for Strut AB in Vector Problems?
5 replies · 9K views · last reply
Rybka
"Determine the design angle θ (0° ≤ θ ≤ 90°) for strut AB so that the 400-lb horizontal force has a component of 500lb directed from A towards C. What is the component of force acting along member AB? Take ϕ = 40°"
x-component: magnitude*cos(θ)
y-component: magnitude*sin(θ)
I understand what is being asked, I'm just unsure as to how I would get that AC component with what is given.
-Rybka
Hi Rybka. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Take ϕ = 40°
Please correct this.
You have 3 forces, they must form a closed triangle. Struts exert their force in line with their length, so this tells you the directions of their contributions.
Are you given the correct answer?
Good evening!
The solution is: θ = 53.5°, ForceAB = 621lb
I figured it out.
The position of the struts in the first diagram is confusing, but the fact that we're solving for θ means their shape is variable.
Once I moved things around a little bit, it all became clear. :smile:
It's always useful to know the answer. I was hoping you'd edit your post so it tells us exactly what is 40°. That would be useful for someone following along.
Good to know you worked it out.
The problem in the drawing does not give accurate dimensions
