How Do You Calculate the Design Angle θ for Strut AB in Vector Problems?
5 replies · 9K views · last reply
Rybka
"Determine the design angle θ (0° ≤ θ ≤ 90°) for strut AB so that the 400-lb horizontal force has a component of 500lb directed from A towards C. What is the component of force acting along member AB? Take ϕ = 40°"
x-component: magnitude*cos(θ)
y-component: magnitude*sin(θ)
I understand what is being asked, I'm just unsure as to how I would get that AC component with what is given.
-Rybka
  • Diagram of a two-member truss: strut AB runs from pin A at upper left to pin B on a vertical wall at right, strut AC runs from A down to pin C on a horizontal floor. A 400 lbs horizontal force points left at A. Angle θ is marked between strut AB and a dashed horizontal line, and angle ϕ is marked between strut AB and strut AC.
Hi Rybka. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Take ϕ = 40°
Please correct this.
You have 3 forces, they must form a closed triangle. Struts exert their force in line with their length, so this tells you the directions of their contributions.
Are you given the correct answer?
Good evening!
The solution is: θ = 53.5°, ForceAB = 621lb
I figured it out.
The position of the struts in the first diagram is confusing, but the fact that we're solving for θ means their shape is variable.
Once I moved things around a little bit, it all became clear. :smile:
  • Left: a bracket with a horizontal 400lbs force arrow at joint A, strut AB at angle θ to a dashed horizontal, and angle φ between AC and AB. Right: force triangle with F_AB, F_AC, 400lbs and labels θ and φ.
It's always useful to know the answer. I was hoping you'd edit your post so it tells us exactly what is 40°. That would be useful for someone following along.
Good to know you worked it out.
The problem in the drawing does not give accurate dimensions
  • Handwritten student notes with a statics diagram: a 400 lb horizontal force at point A, strut AB to a wall at B, member AC to a floor support at C, angle theta marked at A, and a force triangle below with F_AB and F_AC labels.
  • Handwritten force diagram with a resultant FR = 400 lb pointing left, force FAC = 500 lb along AC, unknown FAB along the strut AB, and angle θ and angle 40° marked at C; Arabic notes and sine-law steps follow, solving sin θ = 0.8034 and FAB = 621.15 lb.
