How Do You Calculate the Minimal Path Sum in Coordinate Geometry?
  • Context: MHB
  • Thread starter Thread starter Albert1
The minimal path sum in coordinate geometry can be calculated using reflections of points across the axes. Given points P=(3,7) and Q=(1,5), the shortest path involves reflecting Q across the y-axis to obtain Q' and then reflecting Q' across the x-axis to get Q''. The length of the path k is determined to be 4√10, with points A and B located at (2/3,0) and (0,2) respectively. The final calculation yields x+y+k = 4√10 + 8/3.
  • Understanding of coordinate geometry and reflections
  • Familiarity with distance formulas in a Cartesian plane
  • Knowledge of basic algebraic manipulation
  • Ability to interpret geometric diagrams
  • Study the properties of reflections in coordinate geometry
  • Learn about distance calculations between points in a Cartesian plane
  • Explore optimization techniques in geometric problems
  • Investigate the application of geometric reflections in real-world scenarios
Students and professionals in mathematics, particularly those focused on geometry, optimization problems, and anyone interested in advanced coordinate geometry techniques.
Albert1
P=(3,7),Q=(1,5) ,A=(x,0),B=(0,y)
if k=minimum(PA+AB+BQ)
find: x+y+k
Mathematics news on Phys.org
[sp]
Let $Q'$ be the reflection of $Q$ in the $y$-axis and let $Q''$ be the reflection of $Q'$ in the $x$-axis. The shortest distance between $P$ and $Q''$ is the straight line between them. The shortest path between $P$ and $Q$ (via $A$ and $B$) is obtained by reflecting parts of that line in the axes, as appropriate (the red path in the diagram). The length $k$ of the path is the same as the distance from $P$ to $Q''$, which is $4\sqrt{10}.$ The point $A$ is at $(2/3,0)$ and $B$ is at $(0,2)$. So $x+y+k = 4\sqrt{10} + \frac83$.[/sp]
Opalg said:
[sp]
https://www.physicsforums.com/attachments/2267​
your answer is correct:)
