How Do You Calculate the Solubility and Ksp of Thallous Chloride?
  • Thread starter Thread starter the.flea
    Solubility
The discussion focuses on calculating the solubility and Ksp of thallous chloride after determining that 1.20g remains undissolved in a 400ml saturated solution. The solubility is calculated as 1.20g per 400ml, which translates to a concentration of 0.0125 mol/L. The Ksp is derived using the formula Ksp = [Tl][Cl], resulting in a value of 1.56E-4. Clarifications were made regarding the relevance of the initial 6.5g in the context of the calculations. The steps provided for calculating both solubility and Ksp were confirmed as correct.
the.flea
[SOLVED] Solubility Thallous Chloride
6.5g of thallous chloride is added to 750ml of water at room temperature to determine Ksp. The solution is stirred from time to time over a 4h period. Some thallous chloride does not dissolve and the solution is declared saturated. A 400ml sample of the solution is decanted off and evaporated to dryness. The weight of thallous chloride that remains is 1.20g.
a) What is the solubility of thallous chloride?
b) What is Ksp for thallous sulfate?
TlCl -> Tl +Cl
Ksp=[Tl][Cl]
6.5g=0.027 mol
c=0.036 i don't know what else to if no ksp is given something to get me started would be helpful.thnks
Where is thallous sulfate mentioned in the problem ( part b ) ?
So the solubility of thallous chloride is 1.20g / 400 mL of water without respect to volume change from dissolution of the thallous chloride. Express this in the appropriate units.
oh in part b it is a typo. so 6.5g (750ml) is irrelevant?
No it doesn't matter ; now simply convert the saturated amount of thallous chloride into moles and then use the molecular formula to fill in the values for the Ksp equation to solve for Ksp. Show your steps.
m=1.2g TlCl-->Tl + Cl
mm=239.83g 1 : 1 : 1
n=0.005mol
c=n/v
c=0.0125mol/L
solubility = c
Ksp=[0.0125][0.0125]
=1.56E-4
is this correct?
OK.
Yeah your steps are good.
