How Do You Calculate the Tension in a Rope Pulling a Log Up an Inclined Ramp?
  • Thread starter Thread starter black02
    Rope Tension
The discussion revolves around calculating the tension in a rope that is pulling a log up an inclined ramp. The problem involves a log with a specified mass, ramp angle, coefficient of kinetic friction, and acceleration, all of which are relevant to the forces acting on the log.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the forces acting on the log, including the normal force and friction. There are attempts to set up equations of motion in both the x and y directions, with some participants expressing uncertainty about how to proceed with the calculations for tension.
The discussion is ongoing, with participants sharing their current calculations and questioning their setup. Some guidance has been offered regarding the relationship between the normal force and friction, as well as the importance of free-body diagrams in visualizing the forces involved.
There is mention of potential errors in calculating the normal force and frictional force, which may affect the overall understanding of the problem. The presence of acceleration indicates that the tension force must be greater than the resistive forces acting on the log.
black02
A 212-kg log is pulled up a ramp by means of a rope that is parallel to the surface of the ramp. The ramp is inclined at 29.1° with respect to the horizontal. The coefficient of kinetic friction between the log and the ramp is 0.757, and the log has an acceleration of 0.720 m/s2. Find the tension in the rope.
Fx=ma(of x)
Fy=ma(of y)
i know i have a normal force
this is what i have but i am stuck
how do i set this up?
black02 said:
Fx=ma(of x)
Fy=ma(of y)
You have a block on a ramp. <--[BLOCK]-->
Those (<--) are vectors. They are pointing in opposite directions. One of them is a pulling force and one is a resistive force. The resistive force and the normal force have a relationship which you can use.
Hope this was helpful.
Dot
i have come back to it. this is what i have so far.
force of friction = .757*185.24
f=140.227
i got this using this formula
f = mkn
f = Force of Friction.
mk = Coefficient of kinetic friction.
n = The normal force pressing the surfaces together.
however the object is still accelerating so the tension force is greater just not sure how i get the tension force from this.
This is close. But the forces in the Y direction are N - mg cos 29.1 = 0. You have them as N - m cos 29.1 = 0, so your value for the normal force (and therefore the frictional force) are too low.
ihowever the object is still accelerating so the tension force is greater just not sure how i get the tension force from this.
Have you drawn a free-body diagram? Those help me a lot. You will have an arrow up the incline for T, the tension in the rope. And you will have arrows downward, along the incline for the friction and gravity. These represent vectors, which add up to the total force created by the accelerating mass of the log.
Dot
  • · Replies 38 ·
