How do you calculate the uncertainty in T using graphs?
16 replies · 3K views · last reply
heavystray
i have an equation like this:
Given m(B-V)= 1.2 +- 0.2
How do you calculate the uncertainty in T? (btw, I solve T using graphs by finding the intersection point)
My idea was first to calculate T when m(B-V) =0.2, and I then calculate T when m(B-V)= 1.2 + 0.2(its uncertainty). and then find the difference between the two T. Your help would be greatly appreciated
kuruman said:
Your attachment cannot be viewed.
ughh thanks for pointing that out, sorry!
There is the simple way -- assume that the solution for T is monotone in m(B-V). Evaluate T for m(B-V) = 1.4 and for m(B-V) = 1.0. See what the range is.
Evaluating the error range by looking at a partial derivative of T with respect to m(B-V) and then multiplying by the error bound on m(B-V) sounds like way too much work and may not even be accurate.
Take the derivative of both sides. You get something of the form:
dm(B-V) = (...) dT
where I'm too lazy to figure out the part in parentheses.
Then the error is
dT = dm(B-V) / (...)
then just let dm = 0.2
This assumes that the error is small, so that you can treat the error in T as linearly proportional to the error in m. This will fail if the error is actually not small.
You can invert the equation and solve for T in terms of m(B-V). Then do standard error propagation. Use
$$\frac{{e^{\frac{a}{T}} } } {{e^{\frac{b}{T}}}}=e^{\frac{1}{T}(a-b)}$$
what do you mean the for T is monotone? so the range would be divided by two right? thanks for the reply
Wait, I'm really sorry, the equation supposed to have minus one after e, that's why i can't solve for T in terms of m(B-V) numerically. sorry again for uploading the wrong eq. thanks for the reply
That makes a big difference. Thanks for the clarification.
A function is monotone if it it always increases when its argument increases. Or if it always decreases when its argument increases. If a function is monotone then it takes on its extreme values at the extreme values of its input. This is a less strict condition than "linearly proportional".
The range would not be divided by two. The uncertainty could be different on each side of the measured/computed value.
WIth an uncertainty that is nearly as much as 20% of the measured value it might be wise to discard the assumption of linear proportionality.
What is the value of T that gives m(B-V) = 1.2? I assume it is an experimental number.
if we use the above eq. when
m(B-V)= 1.2, T= 3930
when m(B-V)= 1, T= 4420
when m(B-V)= 1.4, T= 3530
so the uncertainty of T= is 4420-3530?
OR
we have to do it separately on both sides?
upper uncertainty= 3920-3530
lower uncertainty= 4420-3920
Thanks
if we use the above eq. when m(B-V)= 1.2, T= 3930
For m(B-V) = 1.2 I got T = 4960 for log base 2.51. The natural log gave me 3714 which is closer to your value of 3930.
wait, how do you find the 4960?
OR
Thanks
