How do you find the basis for the spanning set which contains matrices?
Given a set of vectors that spans a vector space, the largest subset that contains only independent vectors is a basis. The condition for dependence is that
a_1v_1+ a_2v_2+ \cdot\cdot\cdot+ a_nv_n= 0
with at least on of the scalars non-zero. If it is, say [\itex]a_i\ne 0[/itex], we can solve for the vector v_i as a function of the others and so can drop it from the set.
Here, that equation is
a_1\begin{bmatrix}0& 3\\ 1 & 1\end{bmatrix}+ a_2\begin{bmatrix}4 & 5 \\ 3 & 1 \end{bmatrix}+ a_3\begin{bmatrix}-4 & 1 \\ -1 & 1\end{bmatrix}+ a_4\begin{bmatrix}2 & 1 \\ 1 & 2\end{bmatrix}
= \begin{bmatrix}4a_2- 4a_3+ 2a_4 & 3a_1+ 5a_2+ a_3+ a_4 \\ a_1+ 3a_2- a_3+ a_4 & a_1+ a_2+ a_3+ 2a_4\end{bmatrix}
which is the same as the four equations
4a_2- 4a_3+ 2a_4= 0[/itex]<br /> 3a_1+ 5a_2+ a_3+ a_4= 0<br /> a_1+ 3a_2- a_3+ a_4= 0<br /> a_1+ a_2+ a_3+ 2a_4= 0<br /> <br /> An obvious solution is a_1= a_2= a_3= a_4= 0. If that is the <b>only</b> solution, the four matrices are independent and so are a basis for there span. If there is a solution in which one of the coefficients is non-zero, we can solve for that matrix in terms of the other three and so drop it from the set.
@HallsofIvy: I suspect that lawnmowjob asked this as a homework problem, then either figured it out or got help from somewhere else. Given the shortness of his original post, I doubt that he'll be back. It happens too often in these forums, and makes me reluctant to write out more explicit and helpful discussions like yours.
Anyway, I hid the answer in the middle full stop of my answer.
Cute! I'll have to remember that!
sad, but true. many people just want "the answer", and have little interest in gaining the knowledge.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
