How do you find the initial phase angle?
To find the initial phase angle, φ, for a mass oscillating on a spring, start by using the equation x(t) = A cos(ωt + φ). Given the amplitude (A) of 10.0 cm and the period (T) of 0.500 s, calculate the angular frequency (ω) using ω = 2π/T. At t = 0, the position x(0) is -7.5 cm, which allows for the equation -7.5 cm = A cos(φ) to be set up. Solving this equation will yield the value of the initial phase angle, φ. Understanding the relationship between A, ω, and t is crucial for determining φ accurately.
nukeman
A mass is hanging on a vertical spring, and oscillates in SHM with an amplitude of 10.0 cm, and period 0.500 s. The graph shows its motion as a function of time. At t = 0, the mass is found at x = -7.50 cm below the equilibrium position.
Assuming that x(t) = A cos (ωt + φ), find the value of the initial phase angle, φ.
How do I get started in finding the initial phase angle, φ?
Set x(0) = -7.5 cm and solve for the angle. You know the A and the w, so only one unknown.
Im sorry I don't quite understand. It has to be x(t) = A cos (ωt + φ)
So don't I have to figure out A, ω, and t ? then just solve for φ ?
How come you just put x(0) = -7.5cm ? (I understand why you put x(0))
Thanks very much for the help!
Sorry, I should have written x(0) = A cos(ω*0 + φ) = -7.5 cm.
You WILL have to calculate numbers for ω and A before you can solve for φ.
  • · Replies 23 ·
