How do you integrate dirac delta functions?
To integrate the Dirac delta function for the polynomial δ(x^3 - 4x^2 - 7x + 10), it's essential to identify the roots of the polynomial, which are x = 1, x = -2, and x = 5. The integration can be approached using the property that relates the delta function to its roots, specifically considering the contributions from each root within the integration limits. The factor of 1/|a| in the delta function integration formula is crucial for determining the final result, which in this case leads to an answer of 1/6. Understanding how to apply these principles to higher-order polynomials is key to solving similar problems effectively.
KeithKp
∫δ(x3 - 4x2- 7x +10)dx. Between ±∞.
Well I don't really know how to attempt this. In the case where inside the delta function there is simply 2x, or 5x, I know the answer would be 1/2 or 1/5. Or for say δ(x^2-5), the answer would be 1/√5.
But I'm unsure how to go about this one. Wolfram Alpha states the answer is 1/6. Tried to factor the polynomial which results in (x-1)(x+2)(x-5). But that doesn't seem to help either.
Any guidance would be great thanks!
You are on the right track. You now know what points give a contribution (the roots of the polynomial) if they are inside your integration interval.
Now, do you remember where the factor 1/sqrt5 comes from in the case of x^2-5?
Are you saying that I should only consider the (x-5) and (x-1) roots? Would that then result in the answer being 1/6? Why would I not consider the negative root? :S
I know this relation exists:
∫dx⋅f(x)⋅δ(ax+b) = 1/|a|⋅f(-a-1b). (sorry for the formatting) (limits ±∞ again)
Which I understand makes sense for say δ(2x). Not quite sure how √5 is a in δ(x^2-5). But I get the system. Then I'm really confused for the 3 order polynomial above.
https://www.physicsforums.com/file:///page36image21544 https://www.physicsforums.com/file:///page36image21704
I can see i take the positive root for x^2-5, is that the same thinking for taking (x-5) and (x-1) above? But why is that?https://www.physicsforums.com/file:///page36image21544 https://www.physicsforums.com/file:///page36image21704
\delta(x^2-5) = \delta((x-\sqrt{5})(x + \sqrt{5})) = \delta(2 \sqrt{5} (x - \sqrt{5}) + \delta(-2 \sqrt{5}(x + \sqrt{5}))
...Thank you, I'm an idiot.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 31 ·
