How do you magnetize a circular magnet?
90 replies · 17K views · last reply
Part Toon said:
Thanks, I think I'll try all of that stuff :D
But for a magnet about 2-3" in diameter, made out of ferrite, or iron, or something else, how much "juice" (electricity) would it take to re-magnetize it?
I think that depends very much on the type and condition of the material-you may or may not be able to remagnetize it permanently. Most likely you could make an electromagnet out of it, but the magnetization might not persist upon removal of the (solenoid) field.
Well, hopefully it does :)
I could try different materials until I find the correct one :)
Preferably materials that are already magnets :P
One suggestion I have for you if you want to do in-depth experiments with magnetic rings: Start first with cylindrical magnets of various materials using a cylindrical solenoid. You can even wrap a couple of loops for a probe around the cylindrical sample. It would be much easier to make your observations both by observing the magnetic field outside the cylindrical magnet: Did the poles get reversed?, etc...and comparing to what type of signal you got on an oscilloscope. It is much more difficult to work with rings where you need to hand-wrap every ring and you don't get any appreciable field external to the ring to tell you what is going on inside of it.
I like your idea :smile:
When I get to the point to test different materials, I shall do the cylinder thingy that you mentioned :smile:
My plan...
1. Get a bunch of cylinder magnets of various ferromagnetic materials
2. Test them with solenoids, to find a good ratio of wire-magnet-electricity input
3. Once I find one, obtain a ring of such a material, and then repeat the process with the solenoid
4. Assemble my secret device using my new circular magnet
5. If my secret device finally works this time, after 3 years of working, then I shall begin the next phase of my plan, P.I. (not private investigation if you are wondering)
6. After P.I. is complete, then I'll do a bunch of other stuff that I'll make up as I go :P
65 posts already! :)) :woot: ?:) :nb) :eek: :biggrin:
I never expected this many on my simple questions! :P
I did a google of the topic "reversing the polarity of a permanent magnet" and the answer was very much what I expected. (You might find it worthwhile to google this as well.) For a high quality permanent magnet, it takes a considerable amount of reverse current in the solenoid (for a very brief time). The alternative method of heating above the Curie temperature and applying a reverse magnetic field as it cools doesn't require anywhere near the magnetic field strength in the solenoid that is required for the first case. The magnetic field strength in the first case might be difficult to achieve.
Poster is not seeking to reverse the polarity of a magnet.
The major feat here, if achievable, is to permanently remove all evidence of a magnet ever having been magnetised in a radial direction.
Magnetising it circumferentially will be a cinch, in comparison.
Actually, the goal is to magnetize a magnet by changing the direction of the magnetic domains. Not to reverse them, or remove them, but altering their direction into a clockwise or counter-clockwise manner.
Can't you take a bar magnet, bend it into a circle, then spot weld the ends together?
The welding might demagnetize only a small portion of the bar.
I found this instruction on the web for magnetising materials: http://oersted.com/magnetizing.PDF
The sketch in post #13 gives the geometry for your specific case: wind a solenoid around the doughnut.
The "link" that my2cts provides is interesting. It also details the difficulty of creating the magnetic fields ## B ## in excess of ## B= 1 weber/m^2 ## that would be necessary to change the direction of magnetism of a permanent magnet.
Recently, I was experimenting with a nail, a solenoid made from some sort of TV wire (I think), and a transformer for the 12V input. After a few tries, I made an electromagnet :smile:
With this new knowledge about electromagnets, I have decided to purchase 2x 50-foot long extension cords (I looked, and some are $10 each :wideeyed:), FYI: I have not yet purchased the extension cords. After that, I will disassemble the cords, and pull out the insulated wires that lie within. Then I shall construct a rig to support the "Chuck magnet" mentioned earlier, then I'll wrap the magnet until I run out of wire. I will carefully place the magnet & solenoid into my rig, then I'll attach the wires into a light socket (carefully and precisely) to get 120V rather than a little 12V
Hopefully, after a second or 2 in the rig, it'll be re-magnetized into the form that I require for my secret project :smile:
Don't use a light socket for voltage-it is AC(alternating current). That means the voltage is ## V=V_o \cos(\omega t) ## where ## \omega=2 \pi f ## and ## f=60 Hz ## . If you didn't follow the mathematics, it means the polarity of the light socket voltage switches rapidly back and forth (60 cycles each second). Your 12 volts DC (direct current) should work well. You are more limited by available current than voltage. I would even recommend placing a resistor R=10 ohms that is rated at 1 watt in series in your solenoid circuit so that you don't drain the battery too quickly. You should at least be able to make an electromagnet from your previous magnet that has lost its magnetism. You may or may not be able to make it back into a high quality permanent magnet.
Thanks for that :smile:
Are you sure just 12 volts would work? I do agree with the AC-DC thing, but I may need more voltage, but I don't know for sure :P
So maybe instead of the light socket, I should use the DC transformer I mentioned earlier?
Your solenoid has very low electrical resistance=most likely less than 1 ohm. You could easily drain a 12 volt battery in a minute or two without any additional resistor in the circuit. It is electrical current that makes your solenoid work, but if you have enough loops, you can reduce the current. A 10 ohm resistor would make the current be about 1 amp. That is more than enough to get a good magnetic field if you have enough loops(turns) in your solenoid. Yes, a DC transformer would also work=and you save on money by not needing to purchase batteries. A DC transformer that can deliver high currents (.5 -1.0 amps at 12 volts DC would be helpful and again use a R=10 ohm resistor (rated at 1 watt or more). Without the resistor, you might burn out the DC transformer. Be sure your resistor can handle the power also=(1 watt or more). You can even touch your finger to the body of the resistor and make sure it isn't getting too warm...=be a little careful when connecting circuits like this=components can get hot on occasion and smoke, etc.
Yeah, I can do that.
(I already have a DC transformer that plugs into the wall, so that'll save a lot of time)
This means the last piece of the puzzle is to buy the 2x 50-foot extension cords for about $20 :D
And of course, a bunch of assembly that'll probably take a few hours :P
I edited my post #75. Please read the last couple of sentences to be somewhat careful. Sounds like a fun experiment !
So yes, I shall continue to reply after I purchase the extension cords, assemble the magnetizing device, and test the magnet, and then assemble my secret machine.
When I'm done magnetizing stuff, I'll reply telling you how it went :D
What you are needing cannot be accomplished except by an electromagnet - - - or a permanent magnet array - - - - - composed of many magnet segments, such as a Halbach array, although in your case all the segments would follow in the same direction, head to tail.
Why do you think a permanent magnet cannot be like this? With the round field and all?
Just one additional comment on your closed magnetic rings=it doesn't seem to leave any method to probe the magnetism inside the ring. It is also possible to make a magnetic ring/permanent magnet that has a small air gap in the ring. The magnetic field ## B ## will pass continuously across the air gap. This would allow you to probe the ## B ## in the air gap with a loop of current-carrying wire, etc.
So... possible? :D
FYI: I don't need that much of the flux to escape the magnet, just a little tiny bit.
Magnetism has a directional orientation. The field will be generated strongest parallel to the orientation of the NS poles.
You might want to try this. Take a flat magnet and cut out a circular section. Drill a hole in the circular section. Cut another piece in the magnet to fit the hole. Determine the orientation of the two circular pieces then place the smaller piece in the hole with the 2 north and east directions pointed in opposite directions. This should produce a toroidal effect. If that's isn't what you were looking for try placing the small piece inside the hole with the north and east poles oriented in their correct orientations ( you may have to use a device to keep it from spinning). This may nullify the field lines passing through the center.
I don't think you quite understand what I am going to do, I'm going to use a solenoid made from wires from an extension cord. I'm not going to use the Earth's North and South poles to magnetize my circular magnet, but instead, a very powerful solenoid wrapped around it.
Recommend getting insulated wire of a moderate gauge-don't use an extension cord=the insulation is too thick and will limit how many turns you can make. You can get 100 ft. of insulated wire on a spool for perhaps $5=from Radio Shack. You don't need tremendously thick insulation.
Thanks for the tip :smile:
Instead of buying a 100 ft. extension cord, I shall instead purchase 2 or 3 of those insulated wire spools that you spoke of, how would one word that while looking for it on their website?
Tom.G said:
Hook-up wire.
Danke schön :smile:
(Thank you in German)
ఆసక్తి దాయకంగా ఉంటాయి
(phonetically: Āsakti dāyakaṅgā uṇṭāyi)
(You are welcome in Telugu)
(Google Translate is great. I don't even know where Telugu is spoken!)
There's been a change in plans...
A while ago, I helped my Grandma by shoveling some mud out of her basement after it got flooded :P She gave me 2x 25 foot old extension cords. I took apart one for the wire inside for my experiments, turns out, the wire works great, the insulation isn't too thick :D
I have discovered that a circular solenoid doesn't work the way I was hoping, so instead, I have decided to do it the same way that the core-memory things do, have a bunch of wires go through the center of a ring magnet, making sure that the electricity is flowing all the same directions :P And then maybe hitting the magnet with a hammer a few times to re-position all of the domains :P
I have done a test with a piece of ring-shaped metal, and guess what? It works! :smile:
So after I get a new ring magnet to use (the hole on the "Chuck" magnet is too small), then I can continue with my experiments, and I can finally complete my secret device :smile:
